Backflow option for pressure outlet boundary condition |
April 30, 2014, 02:46 |
Kan
Rep Power: 12 |
For this outlet boundary condition with backflow, I want to set turbulence kinetic energy and dissipation rate for this backflow, what kind of boundary conditions should I set? and how does the code determine that this is backflow? Thanks in advance Kan |
April 30, 2014, 23:45 |
#2 | |
Dr. B T KANNAN
Rep Power: 15 |
-- KANNAN B T |
May 1, 2014, 03:58 |
Kan
Rep Power: 12 |
Thank you very much, KANNAN.
About this inletOutlet BC, it says it switches U and p between fixedValue and zeroGradient depending on direction of U, for the direction of U, does that mean the normal direction of velocity of bounding cell? Kan |
May 1, 2014, 17:16 |
Fumiya Nozaki
Rep Power: 19 |
The direction of U is determined by the sign of the flux ("phi" field) across the patch faces: https://github.com/OpenFOAM/OpenFOAM...FvPatchField.C Code:
template<class Type> void Foam::inletOutletFvPatchField<Type>::updateCoeffs() { if (this->updated()) { return; } const Field<scalar>& phip = this->patch().template lookupPatchField<surfaceScalarField, scalar> ( phiName_ ); this->valueFraction() = 1.0 - pos(phip); mixedFvPatchField<Type>::updateCoeffs(); }
This switching is performed using the mixedFvPatchField: https://github.com/OpenFOAM/OpenFOAM...FvPatchField.C Code:
template<class Type> void mixedFvPatchField<Type>::evaluate(const Pstream::commsTypes) { if (!this->updated()) { this->updateCoeffs(); } Field<Type>::operator= ( valueFraction_*refValue_ + (1.0 - valueFraction_)* ( this->patchInternalField() + refGrad_/this->patch().deltaCoeffs() ) ); fvPatchField<Type>::evaluate(); } Fumiya
[Personal]
May 1, 2014, 20:00 |
#5 | |
Kan
Rep Power: 12 |
It really helps! Kan |
Difficulty in calculating angular velocity of Savonius turbine simulation | alfaruk | CFX | 14 | March 17, 2017 06:08 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 00:00 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
No results for solid domain | Gary Holland | CFX | 10 | March 13, 2009 03:30 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
