New BC patch definition: typeInfo problem with refCast
Old   April 25, 2014, 18:40
Default New BC patch definition: typeInfo problem with refCast
Matt_B is on a distinguished road
Hi everybody,
it was a long time without posting anything, but I always followed the developments of the Forum
Now I'm facing a problem for which I didn't find a soution up to now, by reading other posts on this forums: I hope someone of you can help me, because it is a matter quite annoying to me.
For the solver I'm modifing, I had the necessity to create a new BC, because I didn't find one to suit my needs. I modified the "compressible::turbulentHeatFluxTemperature" calling it "myGradientEnthalpy". Everything worked fine, I created a new library by means of the "make libso" command and I put the reference to it in 'controlDict' for my case.
The problem arised when I decided to fix this BC in the createFields.H header using the refCast word; compiling the solver comes an error message in which seems "myGradientEnthalpy" is not recognized as a type. The error is generated inside the typeInfo.H header at line 110.
As far as I understand, the problem could be solved with one of the macros listed in fvPatchField.H header and used to define a new type by means of typeDef and macro declarations, but I don't know how.; I didn't find yet a method to get the solver compiling process see my new BC even as a new recognized type to make refCast work.
Could someone please give me a clue about this issue?
Thank you in advance.
Matteo
Last edited by Matt_B; April 26, 2014 at 11:14. Reason: wrong reference to fvPatchFields.H
Matt_B is offline   Reply With Quote
Old   April 26, 2014, 11:46
I'm continuing here below the thread if someone is interested to:
http://www.cfd-online.com/Forums/ope...tml#post488381
fvpatchfields.h, patch type, type, typedef
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) Aadhavan OpenFOAM Meshing & Mesh Conversion 2 March 8, 2018 02:47
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 20:43
[GAMBIT] periodic faces not matching Aadhavan ANSYS Meshing & Geometry 6 August 31, 2013 12:25
CheckMeshbs errors ivanyao OpenFOAM Running, Solving & CFD 2 March 11, 2009 03:34
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
