interfoam: a problem with removing convection in the air phase |
March 31, 2014, 22:56 |
xuhe-openfoam
Rep Power: 13 |
hello!
" Water waves create vortices on the air-side of the free surface. These vortices have high velocity, impact the Courant number, push the time step to be smaller, and increase the simulation costs. For many problems, stresses generated on air side are negligible. Solution: ignore convective term on air-side. " said by Eric Paterson in 3rd OpenFoam Workshop. Eric Paterson proposed a similar and effective solution to the problem of high air velocity above the free surface .He modifies air convection in the transport equation by multiplying the phase fraction value to the convective term. In this manner convection is kept intact for those parts of the computational cells with the phase fraction value of 1, and reduced for region with lower phase fraction value accordingly! then , i modify the "UEqn.H" in the interFoam as following (note the red colour) : fvVectorMatrix UEqn ( fvm::ddt(rho, U) + alpha1*fvm::div(rhoPhi, U) + turbulence->divDevRhoReff(rho, U) ); and after wmake , i began to run the "interFoam/laminar/damBreak" case without any modification . but i found the time step is getting smaller and smaller ! at last , the deltaT is about "1.0e-10" s. the modification i did in "UEqn.H" should not produce results like that ! it is counterproductive ! is there something wrong with my operation? could you help me ? thanks. |
interfoam;convection |
Pressure drag problem in porous media with interFoam | skp | OpenFOAM Running, Solving & CFD | 8 | May 27, 2015 08:10 |
Thermal phase change set up problem | Danial Q | Main CFD Forum | 1 | July 10, 2014 14:41 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 07:59 |
Multiphase flow problem | icedou | FLUENT | 6 | July 10, 2005 02:52 |
Help - Two Phase Flow - Convergence Problem | R.Sureshkumar | Main CFD Forum | 1 | February 22, 2000 03:24 |
