Evaporation model in diesel Spray
Old   March 20, 2014, 05:48
Post Evaporation model in diesel Spray
bilal
brbbhatti is on a distinguished road
I am working on the Fuel Injection Spray Model of Diesel Engine and I have some problem related to Evaporation of Urea and Water. I am using Open Foam 2.1.
I am using "LiquidEvaporation Model" for Water and for Urea i am using "SingleKineticRateDevolatilisation Model".
And other properties are
constantProperties
parcelTypeId 1;
rhoMin 1e-15;
TMin 200;
pMin 1000;
minParticleMass 1e-15;
rho0 1087;
T0 333.15;
Cp0 3395;
youngsModulus 1e9;
poissonsRatio 0.35;
epsilon0 1;
f0 0.5;
Tvap 406;
Tbp 465;
Pr 0.7;
LDevol 3086523;
hRetentionCoeff 0;
constantVolume false;
subModels
particleForces
sphereDrag;
injectionModel coneInjection; // patchInjection
dispersionModel stochasticDispersionRAS;
patchInteractionModel localInteraction; // localInteraction | standardWallInteraction
heatTransferModel RanzMarshall;
compositionModel singleMixtureFraction;//singlePhaseMixture;//singleMixtureFraction;
phaseChangeModel liquidEvaporation;
devolatilisationModel singleKineticRateDevolatilisation;
surfaceReactionModel none;
surfaceFilmModel none;
radiation off;
coneInjectionCoeffs
duration 1; // steadyState
positionAxis
So can you help and tell me what constant value is not correct or which parameters in this Spray Model i can change so that i get the Complete or Maximum Evaporation of Urea and Water.
your reply should be really Appreciated.
brbbhatti is offline   Reply With Quote
Old   March 20, 2014, 12:58
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
Which lagrangian solver are you using? If you could post a link to your sprayProperties (or similar) file you are using we could get a better look. It would be good to see the way the devolatilization model is set up.
mturcios777 is offline   Reply With Quote
Old   March 21, 2014, 05:37
bilal
Hi! Marco,
Thanks for your reply and interest. I am Using "SimpleReactingParcelFoam" as lagrangian solver.
And Properties are like that
//massFlowRate 0.001;
massFlowRate 6.41e-6;
parcelsPerInjector 300;
parcelBasisType mass;
flowRateProfile constant 1.0;
Umag constant 32.0;
thetaInner constant 0;
thetaOuter constant 9;
sizeDistribution (Example*)
minValue 100e-06;
maxValue 100e-06;
RanzMarshallCoeffs
BirdCorrection true;
singleMixtureFractionCoeffs
phases
gas
CH4N2O 1;
liquid
//CH4N2O 0.32;
H2O 1;
solid
YGasTot0 0.32;
YLiquidTot0 0.68;
YSolidTot0 0;
singlePhaseMixtureCoeffs
phases
liquid
CH4N2O 0.32;
H2O 0.68;
liquidEvaporationCoeffs
enthalpyTransfer enthalpyDifference;
activeLiquids ( H2O );
singleKineticRateDevolatilisationCoeffs
volatileData (Example*)
(CH4N2O 1.467e35)
liquid
{ CH4N2O;
residualCoeff 1e16;
so this is the example how i use and setup the properties ....so what you think ?? what is the problem that temperature drop is not steady and not physical applicable where i have to do some changes and which factor is more important i can work or focus on or is there any other model i can choose instead of this??
dieselspray, evaporation model, spray evaporation, spray model
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 08:18
model evaporation tfe FLOW-3D 9 July 6, 2015 07:05
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
Evaporation Model brbbhatti OpenFOAM 3 March 21, 2014 05:50
Locating near wall cells for evaporation model mehrdad_kbg OpenFOAM Programming & Development 2 February 4, 2014 03:56
