interFoam blows up with small channels and high pressure |
March 7, 2014, 05:49 |
Rep Power: 13 |
Hi everybody,
I am running an interFoam case with some microchannels connected to two manifolds, one with the inlet and one with the outlet: _________0 <-outlet | | | | | | | | | | | | | | | | | | | | | | | | | | | | 0------------ | inlet I hope thats understandable I can run the case with 1500 Pa pressure at the inlet. The Channels are filled with air at the start and then get flooded with a fluid. It works up to 15 sec and the result looks quite good. Now I want to have higher pressure at my inlet, but the courant number blows up at =~0.0001 s, or the timesteps for adjustableTimeSteps are getting to small. My setup: alpha.coolant: dimensions [0 0 0 0 0 0 0]; internalField uniform 0; boundaryField { wall { type zeroGradient; } inlet { type fixedValue; value uniform 1; } outlet { type inletOutlet; inletValue uniform 1; value uniform 1; } } p_rgh: dimensions [1 -1 -2 0 0 0 0]; internalField uniform 0; boundaryField { wall { type fixedFluxPressure; value uniform 0; } inlet { type fixedValue; value uniform 5e5; } outlet { type fixedValue; value uniform 0; } } U: dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { wall { type fixedValue; value uniform (0 0 0); } inlet { type pressureInletVelocity; value uniform ( 0 0 0 ); } outlet { type zeroGradient; } } fvSchemes: ddtSchemes { default Euler; } gradSchemes { default Gauss linear; } divSchemes { div(rhoPhi,U) Gauss linearUpwind grad(U); div(phi,alpha) Gauss vanLeer; div(phirb,alpha) Gauss linear; div((muEff*dev(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear limited 0.33; } interpolationSchemes { default linear; } snGradSchemes { default limited 0.33; } fluxRequired { default no; p_rgh; pcorr; alpha.coolant; } fvSolutions: solvers { "alpha.coolant.*" { nAlphaCorr 2; nAlphaSubCycles 1; alphaOuterCorrectors yes; cAlpha 1; MULESCorr yes; nLimiterIter 3; solver smoothSolver; smoother symGaussSeidel; tolerance 1e-8; relTol 0; } pcorr { solver PCG; preconditioner DIC; tolerance 1e-5; relTol 0; } p_rgh { solver PCG; preconditioner DIC; tolerance 1e-07; relTol 0.05; } p_rghFinal { $p_rgh; relTol 0; } U { solver smoothSolver; //PBiCG; preconditioner symGaussSeidel; //DILU; tolerance 1e-06; relTol 0; } } PIMPLE { momentumPredictor no; nOuterCorrectors 1; nCorrectors 3; nNonOrthogonalCorrectors 2; } relaxationFactors { fields { } equations { ".*" 1; } } Is there anything obvious that I overlooked? I work with the newest 2.3.0 OpenFoam version. Thanks for your help. Cheers Nils |
high pressure boundary condition | fragzilla | CFX | 5 | September 14, 2012 03:40 |
