February 18, 2014, 04:58 |
OpenFOAM 2.3.0
Joachim Herb
Rep Power: 22 |
Dear OpenFOAMers,
I am not sure, why this was not reported here yet, but a new version of OpenFOAM was released last week (2014-02-10): http://www.openfoam.org/version2.3.0/ https://github.com/OpenFOAM/OpenFOAM-2.3.x Joachim |
February 18, 2014, 05:33 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hi Joachim,
Actually, the release notes are really misleading, because they only announced it yesterday: https://twitter.com/openfoam/statuse...44092042887168 As for the announcement here on the forum, it's stuck in moderation mode: http://www.cfd-online.com/Forums/ope...-v2-3-0-a.html - I don't have permissions to touch that section, so... we'll have to wait Best regards, Bruno |
February 18, 2014, 11:25 |
Joachim Herb
Rep Power: 22 |
Unfortunately, the 2.3.0 breaks swak4Foam compilation (due to a new implementation of mesh interpolation).
February 18, 2014, 14:02 |
Helyx-OS 2.0.0 with OpenFoam 2.3?
Jose Rey
Rep Power: 18 |
Does anybody know if Helyx-OS 2.0.0 will work with OpenFoam 2.3?
Thanks. |
March 2, 2014, 03:42 |
Mehdi GHOZALI
Rep Power: 13 |
Hello Foamers,
I want to know if someone can help installing 2.3.x without deleting the 2.2.2 version already installed on my Ubuntu 12.04 LTS. Thank you and sorry if there's already an answer. Dadou |
March 2, 2014, 03:44 |
Bruno Santos
Rep Power: 128 |
Greetings to all!
@Dadou: Here's some reading material: http://openfoamwiki.net/index.php/In...with_the_Shell - when you finish reading+studying that page, you should be able to install as many OpenFOAM versions and variants as you want Best regards, Bruno
March 2, 2014, 03:48 |
#7 | |
Mehdi GHOZALI
Rep Power: 13 |
Greetings to you Bruno, Thank you for the help Kind Regards, Dadou |
March 3, 2014, 04:46 |
#8 | |
Mehdi GHOZALI
Rep Power: 13 |
I tried to follow and understand the content of the link you send me. now I have two versions of OpenFOAM, but when I open a terminal it's goes directly to the 2.3.0 version. I created two alias of222 for 2.2.2 version and of230 for the 2.3.0 but somehow doesn't read the first one. Can you help me with this please? Thank you Dadou |
March 3, 2014, 06:42 |
#9 | |
Bruno Santos
Rep Power: 128 |
It happened to me in openSUSE and Fedora (if I'm not mistaken) and only after logging out and logging back in, was the environment properly set-up. |
March 3, 2014, 07:36 |
#10 |
Joachim Herb
Rep Power: 22 |
March 3, 2014, 08:45 |
#11 |
Mehdi GHOZALI
Rep Power: 13 |
It happened to me in openSUSE and Fedora (if I'm not mistaken) and only after logging out and logging back in, was the environment properly set-up.[/QUOTE]
I tried what you suggested but still have the same problem and try to follow the web site again but nothing. Do you have an idea about the why? Hope you can help thanks again Regards |
March 4, 2014, 00:35 |
#13 |
Mehdi GHOZALI
Rep Power: 13 |
March 4, 2014, 02:38 |
#14 |
I guess wyldckat meant 'cat $HOME/.bashrc'. Actually even if you created aliases of222 and of230 but have a line 'source /path/to/openfoam/2.3.0/etc/bashrc' in your $HOME/.bashrc you'll get environment variables setup for OF 2.3.0 as soon as you open terminal. |
March 4, 2014, 03:19 |
#15 | |
Mehdi GHOZALI
Rep Power: 13 |
when I run the command you suggested, I have this in return : Code:
openfoam@openfoam:~$ cat $HOME/.bashrc # ~/.bashrc: executed by bash(1) for non-login shells. # see /usr/share/doc/bash/examples/startup-files (in the package bash-doc) # for examples # If not running interactively, don't do anything [ -z "$PS1" ] && return # don't put duplicate lines or lines starting with space in the history. # See bash(1) for more options HISTCONTROL=ignoreboth # append to the history file, don't overwrite it shopt -s histappend # for setting history length see HISTSIZE and HISTFILESIZE in bash(1) HISTSIZE=1000 HISTFILESIZE=2000 # check the window size after each command and, if necessary, # update the values of LINES and COLUMNS. shopt -s checkwinsize # If set, the pattern "**" used in a pathname expansion context will # match all files and zero or more directories and subdirectories. #shopt -s globstar # make less more friendly for non-text input files, see lesspipe(1) [ -x /usr/bin/lesspipe ] && eval "$(SHELL=/bin/sh lesspipe)" # set variable identifying the chroot you work in (used in the prompt below) if [ -z "$debian_chroot" ] && [ -r /etc/debian_chroot ]; then debian_chroot=$(cat /etc/debian_chroot) fi # set a fancy prompt (non-color, unless we know we "want" color) case "$TERM" in xterm-color) color_prompt=yes;; esac # uncomment for a colored prompt, if the terminal has the capability; turned # off by default to not distract the user: the focus in a terminal window # should be on the output of commands, not on the prompt #force_color_prompt=yes if [ -n "$force_color_prompt" ]; then if [ -x /usr/bin/tput ] && tput setaf 1 >&/dev/null; then # We have color support; assume it's compliant with Ecma-48 # (ISO/IEC-6429). (Lack of such support is extremely rare, and such # a case would tend to support setf rather than setaf.) color_prompt=yes else color_prompt= fi fi if [ "$color_prompt" = yes ]; then PS1='${debian_chroot:+($debian_chroot)}\[\033[01;32m\]\u@\h\[\033[00m\]:\[\0 33[01;34m\]\w\[\033[00m\]\$ ' else PS1='${debian_chroot:+($debian_chroot)}\u@\h:\w\$ ' fi unset color_prompt force_color_prompt # If this is an xterm set the title to user@host:dir case "$TERM" in xterm*|rxvt*) PS1="\[\e]0;${debian_chroot:+($debian_chroot)}\u@\h: \w\a\]$PS1" ;; *) ;; esac # enable color support of ls and also add handy aliases if [ -x /usr/bin/dircolors ]; then test -r ~/.dircolors && eval "$(dircolors -b ~/.dircolors)" || eval "$(dirco lors -b)" alias ls='ls --color=auto' #alias dir='dir --color=auto' #alias vdir='vdir --color=auto' alias grep='grep --color=auto' alias fgrep='fgrep --color=auto' alias egrep='egrep --color=auto' fi # some more ls aliases alias ll='ls -alF' alias la='ls -A' alias l='ls -CF' # Add an "alert" alias for long running commands. Use like so: # sleep 10; alert alias alert='notify-send --urgency=low -i "$([ $? = 0 ] && echo terminal || echo error)" "$(history|tail -n1|sed -e '\''s/^\s*[0-9]\+\s*//;s/[;&|]\s*alert$//'\' ')"' # Alias definitions. # You may want to put all your additions into a separate file like # ~/.bash_aliases, instead of adding them here directly. # See /usr/share/doc/bash-doc/examples in the bash-doc package. if [ -f ~/.bash_aliases ]; then . ~/.bash_aliases fi # enable programmable completion features (you don't need to enable # this, if it's already enabled in /etc/bash.bashrc and /etc/profile # sources /etc/bash.bashrc). if [ -f /etc/bash_completion ] && ! shopt -oq posix; then . /etc/bash_completion fi source /opt/openfoam222/etc/bashrc source /opt/openfoam230/etc/bashrc |
March 4, 2014, 03:35 |
#16 |
look at the two last lines of your .bashrc: Code:
source /opt/openfoam222/etc/bashrc source /opt/openfoam230/etc/bashrc You can do one of the following: 1. Comment out (or just remove) these lines and after you start terminal run one of your aliases (of222 or of230) depending on the version you'd like to use. I guess they are defined in $HOME/.bash_aliases? 2. Create a file .OpenFOAM-release with, put there version you'd like to use Code:
echo '2.2.2' > $HOME/.OpenFOAM-release Code:
OF_VER=$(cat $HOME/.OpenFOAM-release) if [ "$OF_VER" == "2.2.2" ]; then source /opt/openfoam222/etc/bashrc fi if [ "$OF_VER" == "2.3.0" ]; then source /opt/openfoam230/etc/bashrc fi |
March 5, 2014, 01:34 |
#17 |
Mehdi GHOZALI
Rep Power: 13 |
Alexeym,
Thank you for the tips, I figured it out why it wasn't working. in the bash file we have set up the aliases and then it will be easy to "call" them. Exemple : Code:
alias of222='source /opt/openfoam222/etc/bashrc |
May 2, 2014, 02:14 |
#18 |
Lucas Mutti
Rep Power: 14 |
Hey guys,
I have been trying to work with the new version of OpenFOAM 2.3.0 and it seems that it does not even run successful cases that I have executed in OpenFOAM 2.2.1. It is frustrating. Do you guys have similar issues? Why is that? Lucas |
May 2, 2014, 07:44 |
#19 |
Bruno Santos
Rep Power: 128 |
Greetings Lucas,
OpenFOAM is constantly evolving. It might be a bit troubling at first, but to me it seems to be for the best, really! Whenever a new version comes out, take the time to read the release notes; for example, for OpenFOAM 2.3.0: http://www.openfoam.org/version2.3.0/ - there you'll find about most of the changes that have been made. The detail then comes when you find a bug... which may or may not have already been fixed in the repository version: http://www.openfoam.org/download/git.php - which means that you might have to build from source code the latest version, in this case OpenFOAM 2.3.x, in order to be able to use OpenFOAM without said bug... As for adapting your cases to the changes, check the changes made in the reference tutorials you've been following as reference. Best regards, Bruno |
May 2, 2014, 15:35 |
#20 |
Lucas Mutti
Rep Power: 14 |
Hey Bruno,
Thanks for the response and the link. It is quite interesting to see the modifications that were done in this new version. I know that it is possible to install ParaView 4.1.0 without installing OpenFOAM 2.3.0 however, I am not sure how. What I do know is that ParaView can be downloaded from their website as a binary RHEL 64 bit. However, the paraFoam utility will not work and the only way to access the case is by creating a .foam extension in the directory. By any chance do you know how to do this? I will post the solution to my problem in case someone comes across it in the future: Code:
leftSolid_to_heater type compressible::turbulentTemperatureCoupledBaffleMixed; Tnbr T; kappa solidThermo; kappaName none; thicknessLayers (1e-3); OPTIONAL kappaLayers (5e-4); OPTIONAL value uniform 300; Code:
laplacian(rhorAUf, p_rgh) Gauss linear limited 0.333; Cheers Lucas Mutti |
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 11:58 |
OpenFOAM Foundation Releases OpenFOAM v2.3.0 | opencfd | OpenFOAM Announcements from OpenFOAM Foundation | 3 | December 23, 2014 03:43 |
OpenFOAM Foundation releases OpenFOAM 2.2.2 | opencfd | OpenFOAM Announcements from ESI-OpenCFD | 0 | October 14, 2013 07:18 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 18:07 |
OpenFOAM Training and Workshop | Hrvoje Jasak | Main CFD Forum | 0 | October 7, 2005 07:14 |
