problem viewing cyclic BC SRFSimpleFoam
Old   February 3, 2014, 15:23
Exclamation problem viewing cyclic BC SRFSimpleFoam
Oscar Urbina
oscar_urri is on a distinguished road
Hello Foamers,
I'm trying to simulate a 2 bladed wind turbine with SRFSimpleFoam,
since the 2 blades are identical, my domain is a hallf tube, with a hole in the middle. (i'll attach and image and my blockMeshDict), and the blade will be represented by a force.
i'm using cyclic bc on both sides of the cut (since it's a point-symetric rotating frame , what comes out of one side should come in the other side).
blockMesh compiles well, but when i try to open the case in paraView i get the following error:
--> FOAM FATAL ERROR:
More than one patch accessing the same transform but not of the same sign.
patch:cyclic_half1 transform:0 sign:1 current transforms1 0 0)
From function Foam::label Foam::globalIndexAndTransform::addToTransformIndex
const label,
const label,
const bool
) const
in file lnInclude/globalIndexAndTransformI.H at line 240.
FOAM exiting
i've also tried declaring them as a wall and the using the createPatch utility with the same results.
i read some threads and thought it might be the way i declare the faces so i've check out the mixer tutorial ( it also uses the cyclic bc), runned the case once, and then i changed the point locations so that instead of the wedge it would be a half tube like my case, and i got the exact same error message.
i think that paraView has a conflict with cyclic boundaries on the same plane.
cause the case seems to run fine, but i can't see the results in paraView.
so my questions are:
has anyone had a problem like this?
is there another BC that may do the trick? like a point-symetric bc?
i was thinking about using symmetry plane, but does it take into account the rotating frame, with that i mean will it map what come out of one side into the other?
thanks for the help in advance
Oscar
oscar_urri is offline   Reply With Quote
Old   February 3, 2014, 15:25
Oscar Urbina
i had to declare all boundaries as wall to be able to take the screen shot, i thought i might clear this out to avoid confusion.
crash, cyclic bc, paraview, srfsimplefoam
Using sprayFOAM on cyclic problem with wedge boundaries Mentalo OpenFOAM Running, Solving & CFD 5 September 7, 2018 03:12
[Other] problem with cyclic BCs michel1988 OpenFOAM Meshing & Mesh Conversion 0 July 4, 2013 05:59
Problem with cyclic patches sven OpenFOAM Running, Solving & CFD 0 December 5, 2011 15:27
[Commercial meshers] Handling cyclic BC from gambit to openfoam for a cascade airfoil problem - OF 1.6 maverick OpenFOAM Meshing & Mesh Conversion 2 June 18, 2011 05:36
cyclic BC from gambit to openfoam for cascade airfoil problem maverick OpenFOAM 0 April 13, 2010 16:18
