Computer capacity to run an important mesh on OpenFOAM
Old   December 19, 2013, 02:02
Default Computer capacity to run an important mesh on OpenFOAM
Mehdi GHOZALI
Dadou is on a distinguished road
Dear everyone,
I start working in a company and they don't use OpenFOAM but they want to run some test cases to see if it worths using it.
So, I have installed it on my computer (Ubuntu virtualbox) just to run some tests and show to the boss it's capacity.
Now they want to install it on the their server, so they need to know what kind of CPU/GPU, RAM they need to run a "big" OpenFOAM test (by big I mean with more then 5,000,000 elements).
Thank you and hope someone can help as quick as you can.
Dadou
Dadou is offline   Reply With Quote
Old   December 19, 2013, 02:50
mechy is on a distinguished road
you can see the tutorial cases of openfoam and you will find that OF can solve many CFD problems
for 5 millions elements I propose the following
RAM 16 Giga bayt
cpu core i7 intel 3.6 GHz
Graphics 4 Giga bytes
mechy is offline   Reply With Quote
Old   December 19, 2013, 04:24
Default Workstation/Cluster
skyinventorbt's Avatar
Dr. B T KANNAN
skyinventorbt is on a distinguished road
Originally Posted by Dadou View Post
Dear everyone,
Dadou
I am using HP Z800 workstation with Xeon processors(12 cores) 16Gb Ram, 2Gb Graphics card...
From my experience Ram you need is around a Gb per million cell for simulation alone.
Processors (100,000 cells per processor - for parallel processing)
My suggestion would be a workstation of the configuration said above - (slow)
or
A cluster with 60~70 cores (relatively fast)
But these configurations also depend on the problem you are simulating...
KANNAN
skyinventorbt is offline   Reply With Quote
Old   January 13, 2014, 03:31
Mehdi GHOZALI
what model of XEON?
100k cells per processor, per core or per thread?
Thanks
Old   January 13, 2014, 03:50
Smile Answer
Dr. B T KANNAN
what model of XEON?
Thanks
X5650
100k cells per core
KANNAN B T
Old   January 13, 2014, 06:31
Mehdi GHOZALI
Thank you
Dadou
Old   January 13, 2014, 12:01
eRzBeNgEl is on a distinguished road
100k cells per core
100k, this is just a rule of thumb. In my cases OF scales up to 10k cells each cpu. So after investing in your workstation make a scalability study.......
eRzBeNgEl is offline   Reply With Quote
Old   January 13, 2014, 16:01
Mehdi GHOZALI
Which case can be a good scalability study ?
Old   January 14, 2014, 02:35
Onno
Kaskade is on a distinguished road
Since it's highly case dependent, the test case should represent what you are trying to do later on.
Kaskade is offline   Reply With Quote
Old   January 14, 2014, 04:30
Mehdi GHOZALI
Thank you, I'll try to find sth that is similar to the cases I'll have
Dadou
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
OpenFOAM Foundation releases OpenFOAM 2.2.2 opencfd OpenFOAM Announcements from ESI-OpenCFD 0 October 14, 2013 08:18
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 07:42
Converting Starccm+ mesh Ladnam OpenFOAM 0 September 14, 2011 07:30
salome, openfoam and moving mesh prhlava OpenFOAM Running, Solving & CFD 8 November 9, 2009 09:59
