Sloshing dissipation
Old   November 16, 2013, 23:11
Default Sloshing dissipation
musaddeque hossein
musahossein is on a distinguished road
Dear all:
I am running sloshingtank2d with discrete displacement data. OpenFOAM nicely shows the sloshing phenonmenon due to the input data. However, I am interested in trying to figure out how long after the input has stopped, will the sloshing continue and finally dissipate? I added 100 data points of zero displacement to the end of the displacement input file, but OpenFOAM continues repeat the sloshing. This is not correct. Assuming that the friction between the fluid and the tank wall will dissipate the sloshing, how can I introduce some friction so that the sloshing is more realistic and will eventually die out?
I look forward to your comments / thoughts on this.
Thankyou in advance.
musahossein is offline   Reply With Quote
slishing dissipation, tank wall friction, wall friction
Turbulent dissipation rate effect turbine torque?? sedongjjang FLUENT 0 August 24, 2012 15:13
Turbulent dissipation rate effect turbine torque?? sedongjjang FLUENT 0 August 24, 2012 15:12
CFX12 rif errors romance CFX 4 October 26, 2009 14:41
Dissipation rate access K. Kevala FLUENT 0 July 14, 2004 12:11
calculation of (turbulent) dissipation energy ? max Main CFD Forum 3 August 18, 1999 10:42
