Scolution convergence problem with SRF model Hex mesh
Old   October 20, 2013, 06:56
Default Scolution convergence problem with SRF model Hex mesh
Nitin Suryawanshi
suryawanshi_nitin is on a distinguished road
Dear Fiends,
I m facing problem in convergence for singleSRF case, getting very high velocity, even though continuity Error=0.005, details are as given below,
1. Geometry: Single periodic passage of fan with vortex generators added on on blades. Plz see the geometry image attached below.
2. Mesh: Hexahedral Mesh created in ICEM with blockling, Quiltiy 3X3 determinant=0.7. checkMesh utility shows everything ok. Orthogonality: max-68, avg-27 is check is Ok. total element count 1.59lakh.
3. I set non orthogonality corrector 10 in system / fvsolutions file
Kindly waiting for reply.....
Thank You in advance...
File Type: jpg Screenshot from 2013-10-20 15:18:30.jpg (66.1 KB, 32 views)
File Type: jpg Screenshot from 2013-10-20 15:19:17.jpg (97.9 KB, 26 views)
suryawanshi_nitin is offline   Reply With Quote
Old   July 5, 2014, 04:06
Huang Xianbei
huangxianbei is on a distinguished road
Originally Posted by suryawanshi_nitin View Post
Dear Fiends,
Hi, I'm facing the same problem for getting unreal velocity and pressure, have you solve this problem?
huangxianbei is offline   Reply With Quote
Gambit problems Althea FLUENT 22 January 4, 2017 04:19
This mesh contains patches of type empty but is not 1D or 2D oric OpenFOAM Running, Solving & CFD 36 November 28, 2016 08:12
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
[Gmsh] gmshToFoam problem: not the same mesh in Gmsh vs. paraview zhernadi OpenFOAM Meshing & Mesh Conversion 8 July 7, 2011 03:28
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 11:09
