Set up one valve and no piston on engineFoam
Old   October 8, 2013, 18:10
Default Set up one valve and no piston on engineFoam
Lachapelle Maxime
Chapelle is on a distinguished road
Hi everyones,
I'm a new user on OpenFoam and i encounter some difficulties to define my geometry on engineFoam. I would like to fix only one valve and suppress the piston.
So i add in the engineGeometry informations relative on valve and piston. but when i'm looking the results with Paraview i obtain the same geometry than the kivaTest tutoriel(4 valves,piston).
Is it others folders to modify except engineGeometry?
Thanks a lot
Max.
Chapelle is offline   Reply With Quote
Old   October 8, 2013, 19:09
Sasan Ghomi
sasanghomi is on a distinguished road
Hi
If you want to change the geometry you should import a mesh in openfoam from other software Or you should create the mesh in openfoam { by using blockMesh Or Snappyhexmesh }
engineGeometry is a dictionary for solver . It's not related to preprocessing .
Hope this helps
sasanghomi is offline   Reply With Quote
