Symmetry plane and errors
Old   September 18, 2013, 22:37
Default Symmetry plane and errors
You
sherandlock is on a distinguished road
I am running a cylinder flow case with icofoam. In the tutorial, it gives a symmetry problem. But now I am running the whole geometry. I set the top and bottom boundary as symmetry plane as in the tutorial. But I got a time step continuity error.
I am a starter for Openfoam and I don't know how to set the boundary conditions in this case. could someone enlighten me on the boundary condition a little bit?
sherandlock is offline   Reply With Quote
Old   September 18, 2013, 23:42
Default Help
You
Attached is my mesh.
I would appreciate your help very much!
Old   September 19, 2013, 07:23
Sasan Ghomi
sasanghomi is on a distinguished road
Hi ,
I have done this simulation. Correct your boundary conditions as follow :
| \\      /  F ield         | OpenFOAM Extend Project: Open Source CFD        |
|  \\    /   O peration     | Version:  1.6-ext                               |
|   \\  /    A nd           | Web:      www.extend-project.de                 |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      p;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    cylinder
        type            zeroGradient;
    //up
    shadow-6
        type            zeroGradient;
    //down
    periodic
        type            zeroGradient;
    inlet
        type            zeroGradient;
    outlet
        type            fixedValue;
        value            uniform 0;
    frontAndBackPlanes
        type            empty;
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    cylinder
        type            fixedValue;
        value            uniform (0 0 0);
    //up
    shadow-6
        type            fixedValue;
    //down
    periodic
        type            fixedValue;
    inlet
        type            fixedValue;
        value           uniform (1 0 0);
    outlet
        type            zeroGradient;
    frontAndBackPlanes
        type            empty;
The boundary of circular cylinder is wall It is Not symmetry !!!
Hope this helps.
P.S. Also take a look at this thread :
http://www.cfd-online.com/Forums/ope...-cylinder.html
sasanghomi is offline   Reply With Quote
Old   September 19, 2013, 14:34
You
Hi sasanghomi,
Thank you very much!
I follow your instruction and have fixed the problem!
Best regards
Sherlock
Old   September 19, 2013, 23:22
You
Originally Posted by sasanghomi View Post
Hi ,
FoamFile
    version     2.0;
    format      ascii;
    object      p;
boundaryField
    cylinder
        type            zeroGradient;
    //up
    shadow-6
        type            zeroGradient;
    //down
    periodic
        type            zeroGradient;
    inlet
        type            zeroGradient;
    outlet
        type            fixedValue;
        value            uniform 0;
    frontAndBackPlanes
        type            empty;
FoamFile
    version     2.0;
    format      ascii;
    object      U;
boundaryField
    cylinder
        type            fixedValue;
    //up
    shadow-6
        type            fixedValue;
    //down
    periodic
        type            fixedValue;
    inlet
        type            fixedValue;
    outlet
        type            zeroGradient;
    frontAndBackPlanes
        type            empty;
Hope this helps.
Hi, Sasan,
Is the top and down also type of wall in this case?
I still get numerical problem and I set them all as wall
Old   September 20, 2013, 04:03
Sasan Ghomi
Yes , they are walls . your domain should be big.Paste the error command here.
DSMC errors at inflow and outflow boundary wenjie OpenFOAM 5 February 21, 2013 00:27
Numerical errors in nested domain with pre-calculated boundary values Arnoldinho OpenFOAM Running, Solving & CFD 3 April 4, 2012 11:31
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 11:56
pipe flow with heat transfer Fabian OpenFOAM 2 December 12, 2009 05:53
Could someone please assist? Plane Waves Bob Main CFD Forum 8 April 11, 2007 02:31
