pressure and velocity in OpenFoam is smaller than Fluent |
September 18, 2013, 06:32 |
how I can increase the accuracy of pressure ?
Rep Power: 15 |
Hi all
I have simulated flow around a cylinder by OF and FLUENT In both software, I use a high quality and fine structure mesh which lead to y+<5 over walls and use Kw-sst model also the setting for OF and FLUENT is as follow FLUENT BCs: inlet ========> velocity inlet U=7m/sec k=.2 omega=170 outlet=======> pressure outlet FLUENT settigs solver =============> PISO residual=1e-5 In OF I have used pimpleFoam and setting are as follow any help will be appreciated Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM Extend Project: Open source CFD | | \\ / O peration | Version: 1.6-ext | | \\ / A nd | Web: www.extend-project.de | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object k; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [ 0 2 -2 0 0 0 0 ]; internalField uniform 0.2; boundaryField { wallup { type kLowReWallFunction; value uniform .2; } outlet { type inletOutlet; inletValue uniform .2; value uniform .2; } inlet { type turbulentIntensityKineticEnergyInlet; intensity 0.02; value uniform .2; } circle { type kLowReWallFunction; value uniform .2; } frontAndBackPlanes { type empty; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM Extend Project: Open source CFD | | \\ / O peration | Version: 1.6-ext | | \\ / A nd | Web: www.extend-project.de | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; location "0"; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [ 0 1 -1 0 0 0 0 ]; internalField uniform ( 0 0 0 ); boundaryField { wallup { type fixedValue; value uniform ( 0 0 0 ); } circle { type fixedValue; value uniform ( 0 0 0 ); } inlet { type fixedValue; value uniform ( 7. 0 0 ); } outlet { type inletOutlet; inletValue uniform ( 0 0 0 ); value uniform ( 0 0 0 ); } frontAndBackPlanes { type empty; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM Extend Project: Open source CFD | | \\ / O peration | Version: 1.6-ext | | \\ / A nd | Web: www.extend-project.de | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [ 0 2 -2 0 0 0 0 ]; internalField uniform 0; boundaryField { wallup { type zeroGradient; } circle { type zeroGradient; } inlet { type zeroGradient; } outlet { type fixedValue; value uniform 0; } frontAndBackPlanes { type empty; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM Extend Project: Open source CFD | | \\ / O peration | Version: 1.6-ext | | \\ / A nd | Web: www.extend-project.de | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object omega; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [ 0 0 -1 0 0 0 0 ]; internalField uniform 170; boundaryField { wallup { type omegaWallFunction; value uniform 170; } wallp { type omegaWallFunction; value uniform 170; } outlet { type inletOutlet; inletValue uniform 170; value uniform 170; } inlet { type turbulentMixingLengthFrequencyInlet; mixingLength 0.005; phi phi; k k; value uniform 170; } plate { type omegaWallFunction; value uniform 170; } circle { type omegaWallFunction; value uniform 170; } frontAndBackPlanes { type empty; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM Extend Project: Open source CFD | | \\ / O peration | Version: 1.6-ext | | \\ / A nd | Web: www.extend-project.de | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object nut; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [ 0 2 -1 0 0 0 0 ]; internalField uniform 0; boundaryField { wallup { type nutUSpaldingWallFunction; value uniform 0; } wallp { type nutUSpaldingWallFunction; value uniform 0; } outlet { type calculated; value uniform 0; } inlet { type calculated; value uniform 0; } plate { type nutUSpaldingWallFunction; value uniform 0; } circle { type nutUSpaldingWallFunction; value uniform 0; } frontAndBackPlanes { type empty; } } // ************************************************************************* // Last edited by mechy; September 20, 2013 at 17:24. |
September 18, 2013, 09:56 |
Andre Weiner
Rep Power: 14 |
Hello!
I don't have OF 1.6-ext installed, so i it's difficult to know what the bc's for k, omega and nut do. In your case (simple geometry) i would just set the following settings : k - zeroGradient omega - an automatic wallfunction like here nut - 0 or calculated Also note that the implementation of k-omega-sst may not be the same as there are various types of source terms (for example for near-wall treatment). How do you control the residuals (fvSolution file)? Hope i could help! Best regards |
September 18, 2013, 11:11 |
Rep Power: 15 |
Hi
thanks for reply I use the OF 2.2 not 1.6-ext (only the header have 1.6) also my fvScheme an fvSolution are : Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.3 | | \\ / A nd | Web: http://www.openfoam.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { p { solver GAMG; tolerance 1e-5; relTol .0; smoother GaussSeidel; nPreSweeps 1; nPostSweeps 2; cacheAgglomeration true; directSolveCoarsest true; agglomerator faceAreaPair; nCellsInCoarsestLevel 20; mergeLevels 1; minIter 1; } pFinal { solver GAMG; tolerance 1e-8; relTol 0; smoother GaussSeidel; nPreSweeps 1; nPostSweeps 2; cacheAgglomeration true; agglomerator faceAreaPair; nCellsInCoarsestLevel 20; mergeLevels 1; minIter 1; } "(U|k|omega)" { solver PBiCG; preconditioner DILU; tolerance 1e-5; relTol 0; nSweeps 1; minIter 1; } "(UFinal|kFinal|omegaFinal)" { solver smoothSolver; smoother GaussSeidel; tolerance 1e-6; relTol 0.0; nSweeps 1; minIter 1; } } PIMPLE { nOuterCorrectors 10; nCorrectors 2; nNonOrthogonalCorrectors 3; pRefCell 0; pRefValue 0; // momentumPredictor yes; ddtPhiCorr no; correctPhi no; } relaxationFactors { fields { p 0.3; } equations { U 0.7; k 0.7; omega 0.7; } } cache { grad(U); } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default Euler; } gradSchemes { default Gauss linear ; } divSchemes { default none; div(phi,U) Gauss limitedLinearV 1; div(phi,k) Gauss limitedLinear 1; div(phi,omega) Gauss limitedLinear 1; div((nuEff*dev(T(grad(U))))) Gauss linear; div((nuEff*dev(grad(U).T()))) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } fluxRequired { default no; p; } |
September 18, 2013, 12:37 |
Andre Weiner
Rep Power: 14 |
Have you tried to run the simulation in pure PISO mode?
It shouldn't make any difference but i think it's worth a try. How much is the difference between the results? Do the fields look similar in both simulations? |
September 18, 2013, 17:19 |
Rep Power: 15 |
the flow field in both of them, are similar
but the value of pressure has a about 10% difference the min p in OF about 10 pa greater than FLUENT for example if p in OF = -50 in FLUent minp=-60 |
Matching Velocity and Pressure fields Fluent OpenFoam | alimansouri | OpenFOAM Running, Solving & CFD | 0 | January 13, 2009 18:51 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 03:15 |
Variables Definition in CFX Solver 5.6 | R P | CFX | 2 | October 26, 2004 03:13 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 06:13 |
