multiphaseInterFoam, velocity appears from nowhere
Old   September 10, 2013, 05:22
Smile [Solved] multiphaseInterFoam, velocity appears from nowhere
a
Leo43 is on a distinguished road
I have only few experience on OpenFoam and I have a problem that I can not solve...
I have a cylinder filled with 2 different fluids with different density, the fluid with the lower density is on the upper part.
checkMesh.log.txt
(the mesh is quite inaccurate, but even if I do it more precisely, this problem still appears).
The cylinder is closed (every boundary condition = wall )
Every initial condition (internal/boundary conditions, p_rgh, U, alphas) are set up to uniform0 or ZeroGradient, and there is no initial velocity.
p_rgh.txt
U.txt
So, I was expecting that the system remains stable in the time, I mean always egal to the initial configuration.
But, after lauching the simulation, a velocity appears inside the cylinder from nowhere, for example here, after 200s computation, we have a max velocity of 0.03 m/s around the interface of the 2 fluids.
I don't know where is my mistake... Can someone helps me to solve this ?
Thank you !
Leo43 is offline   Reply With Quote
Old   September 10, 2013, 05:45
Pablo Higuera
Phicau is on a distinguished road
Hi Leopold,
these are the infamous "parasitic currents" (a.k.a. "spurious velocities") that appear due to the kind of VOF function used in OpenFOAM.
There are lots of information about them in the forum, you should take some time to learn about them, but in short, no one has been able to make them disappear (yet).
Best,
Pablo
Phicau is offline   Reply With Quote
Old   September 10, 2013, 06:22
a
Ok !
Thank you very much Pablo, as you had suggested, I will look for information about this problem, as I can now put a name on it !
Leo
help with UDF for contact angle based on contact line velocity gandesk Fluent UDF and Scheme Programming 14 October 29, 2012 14:58
Steady pipe flow mean velocity higher than inlet velocity anita OpenFOAM Running, Solving & CFD 7 September 25, 2012 06:35
Velocity in Porous medium : HELP! HELP! HELP! Kali Sanjay Phoenics 0 November 6, 2006 07:10
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 03:15
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
