Calculation of initial k for RAS turbulence models |
Baris (Heewa)
Rep Power: 13 ![]() |
Dear Foam users,
I want to ask about the initial calculation of k (turbulence kinetic energy). I am studying cavitating flow inside of the nozzle with different turbulence models ( kepsilon, RNGkepsilon, kwSST). According to users guide k is calculated with this formula: k=3/2(u)^2 u corresponds to fluctuating velocity which equals to 5% of inlet velocity. Just i am confused about this point. As you can see in the attached figure i have one domain inlet (Vin=3.1 m/s) and one nozzle inlet (Vin=12.8m/s). AS you know that cavitation and turbulence take place close the nozzle inlet. I tried both inlet velocity for calculation initial value of k and final result of calculation not change too much, but i want to know that which inlet velocity value should be used for initial calculation of k for the nozzle flows. thanks in advance. |
Ehsan
Rep Power: 26 ![]() |
i think you better set the values of main entrance for velocity and length(for omega or epsilon formulas)
Because only at boundaries you should use a model,the rest of geometry should be solved by the solver itself. Correct me if anyone has another opinion.
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King. To Be or Not To Be,Thats the Question! The Only Stupid Question Is the One that Goes Unasked. |
alphaEqn.H in twoPhaseEulerFoam | cheng1988sjtu | OpenFOAM Bugs | 15 | May 1, 2016 16:12 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
AMI interDyMFoam for mixer nu problem | danny123 | OpenFOAM Programming & Development | 8 | September 6, 2013 02:34 |
lift and drag on ship superstructures | vaina74 | OpenFOAM Running, Solving & CFD | 3 | June 8, 2010 12:30 |
Problems with simulating TurbFOAM | barath.ezhilan | OpenFOAM | 13 | July 16, 2009 05:55 |
