why pimple foam used under relaxation in all iteration of pimple Loop ?
Like Tree28Likes
Old   June 6, 2016, 11:25
Stefan
StefanW is on a distinguished road
Hey Guys,
could somebody please explain me the difference according the relaxationFactors using:
equations
"(U|k|omega)" 0.3;
or using:
equations
k 0.3;
omega 0.3;
U 0.3;
Are the one solved implicit and the others explicit ??
But I thought equations are always solved implicit?
And what is the advantage ? Could you please help me out?
Thanks a lot
StefanW is offline   Reply With Quote
Old   June 7, 2016, 02:47
akidess's Avatar
Anton Kidess
The advantage is that you can tune all three equations with one change instead of three. It's pure convinience. You'll see that notation in other places too.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   June 7, 2016, 04:19
Stefan
Hi Akidess,
thanks for your quick reply.
That helps a lot.
Best Regards
Stefan
Old   June 7, 2016, 04:43
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
Hey Stefan, but normally you don't need such low under-relaxation factors for the turbulent paramters.
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   June 7, 2016, 04:47
Stefan
Hey Rodriguez,
thanks for your comment.
I know they are a little bit rough. So I will try step by step to enlarge them.
Sadly I got a really dynamic problem which colapses without underrelaxation.
Lets see how far i can bring them
Regards
Stefan
Old   June 7, 2016, 05:04
Philipp
Good luck
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
NACA0012 geometry/design software needed Franny Main CFD Forum 13 July 7, 2007 16:57
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
