buoyantPimpleFoam calculates non-physical thick boundary layers/velociities in pipe |
July 30, 2013, 20:24 |
Joachim Herb
Rep Power: 22 |
I have a problem with buoyantPimpeFoam reported at the official bug tracker: http://www.openfoam.org/mantisbt/view.php?id=936 The test case (attached to the bug report) for a (2D) pipe flow simulated with buoyantPimpleFoam results in (non-physical) too thick boundary layers at the walls and therefore in a (much) too high central velocity in the pipe. Using buoyantSimpleFoam to simulate the same case shows results as expected. (Using the stationary result as initialization for the transient calculation does not help.) (Doubling the number elements in the radial direction does not help either.) Any help is appreciated Thank you Joachim buoyantSimpleFoam with buoyantPimpleFoam after 2 s (its getting worse and worse): Last edited by jherb; July 31, 2013 at 05:25. |
boundary layer, boundary layer thickness, buoyant flow, buoyant solver, buoyantpimplefoam |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 06:36 |
domain imbalance for enrgy equation | happy | CFX | 14 | September 6, 2012 02:54 |
Boundary layer thickness in pipe entrance | Bo Jensen | Main CFD Forum | 2 | April 6, 2007 23:53 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 22:31 |
