#21 | |
zooid
Rep Power: 15 ![]() |
you can check these two applications: 1. blender 2. FreeCAD they are both opensource applications, and can export mesh in stl and many other formats. Regards. |
#22 |
Dr. B T KANNAN
You could use SALOME - Open Source CAD Package.
-- KANNAN |
#23 |
Rep Power: 13 ![]() |
Hi Artur,
I have a problem. how i can start simple mixing in vessel problem ? i have vessel dimesnions & impeller dimesnions, how to do meshing in 2D? |
#24 |
Artur
Rep Power: 20 ![]() |
Try something like $FOAM_TUTORIALS/incompressible/pimpleDyMFoam/mixerVesslAMI2D. You can have a look at the propeller tutorial in the same directory too, both have a slightly different philosophy (blockMesh vs snappyHexMesh) but, essentially, lead to the same result.
Peace, A |
#25 |
Rep Power: 12 ![]() |
Does baffle work in OF-1.6-ext and solid mechanics, please? I ran T-junction and damBreakPorousBaffle in OF-1.6-ext but there is no baffle zone in their paraView results. In addition, there is an error in their log.topoSet and log.createBaffles. I want to use baffle to define an internal BC in a solid simulation. Thanks. |
#26 |
Artur
Have a look at this example where an internal patch definition is defined using OF 1.6-ext. Please note that I am used to using more recent versions of OF so the syntax I put into this case might not be the most efficient but it seems to work at least. All the best, A |
OpenFOAM - Validation of Results | Ahmed | OpenFOAM Running, Solving & CFD | 10 | May 13, 2018 18:28 |
2009 OpenFOAM Summer School in Zagreb, Croatia | hjasak | OpenFOAM Announcements from Other Sources | 0 | March 27, 2009 12:08 |
Summer School on Numerical Modelling and OpenFOAM | hjasak | OpenFOAM | 5 | October 12, 2008 13:14 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 18:07 |
Getting OpenFOAM to coexist with an existing JAVA VM | nik777 | OpenFOAM Installation | 5 | February 22, 2007 07:21 |
