rhoPimpleFoam
Old   July 2, 2013, 02:15
Default rhoPimpleFoam
starter
sihaqqi is on a distinguished road
Hi
I have completed LES of my geometry using pisoFoam for incompressible part. Now I am using rhoPimpleFoam. I have modified all parameters required for my geometry and copied ones which shall be same from pisoFoam 0. I am having error attached in the two images but I do not have any file which would say wall. Can anyone explain the source of error.
Regards
sihaqqi is offline   Reply With Quote
Old   July 2, 2013, 03:32
Akshay Kumar
Akshay is on a distinguished road
Hey there!
The wall functions are different for compressible solvers. You might want to check that first.
Akshay is offline   Reply With Quote
Old   July 2, 2013, 05:55
starter
Hello
I am following pitzDaily tutorial and there is the same k file. I have only put in my parameters.
regards
Old   July 2, 2013, 06:42
T. Chourushi
Tushar@cfd is on a distinguished road
Originally Posted by sihaqqi View Post
Hello
regards
When, you will look at the error you will come to know an unknown patchfield for the wall.
In your case you are trying to use an unknown boundary patch (eg., kqRWallFunction) for the LES (oneEqEddy) turbulence model.
Try using the mentioned valid patchfields for the given turbulence model.
I am little confused! How you ran your PISO solver using the LES (oneEqEddy) model, with the same boundary patch (kqRWallFunction)?
Tushar@cfd is offline   Reply With Quote
Old   July 2, 2013, 10:54
starter
Hello Tushar
In the mentioned patchlists, kqRWallFunction is available to be used. In piso, it ran successfully number of times, if files were not heavy, I would have uploaded them on rapid share for you to see, Also, if you like I can upload the file without complete time step solution for piso. I have uploaded the current compressible files folder at the following link.
http://rapidshare.com/files/2869658194/elbow.tar.gz
If you can spare a few minutes I shall be extremely grateful. It is only 4MB in compressed folder. Since you are a senior member whereas I have only started. I am a postgrad student doing MS by research trying to learn CFD.
Thanks for your help.
Old   July 3, 2013, 06:26
T. Chourushi
I am not able to download your files...
Can you copy paste the folder files here...
(1) 0 folder - k file
(2) constant folder - all files
(3) system folder - controlDict, fvSolution, fvScheme files
Old   July 3, 2013, 07:25
starter
if you cannot download it, perhaps you can send me your email address as I cannot paste any file here. this forum support the file extensions openFoam has. I have tried to download from the link, it is working. perhaps you want to try again or I can email you compressed folder
Thanks
Old   July 3, 2013, 07:32
T. Chourushi
Actually, at my work-place many web-links are blocked (especially rapidshare, etc). Can you share your email-id here I will contact you.
Old   July 3, 2013, 07:38
starter
email: sihaqqi@gmail.com
error, rhopimplefoam
rhoPimpleFoam Boundary Condition Problem dancfd OpenFOAM Pre-Processing 18 September 16, 2021 08:43
rhoPimpleFoam floating point error dancfd OpenFOAM Running, Solving & CFD 6 January 5, 2014 21:57
Questions about buoyantPimpleFoam and rhoPimpleFoam Mojtaba.a OpenFOAM Running, Solving & CFD 6 August 1, 2012 05:50
rhoPimpleFoam aborting with floating point exception (because of wrong bc p?) space OpenFOAM Running, Solving & CFD 2 October 5, 2011 06:44
RhoPimpleFoam calculation of natural and forced convection Daniel_Jung OpenFOAM 0 September 22, 2010 06:02
