Problem with sample and fieldAverage
Old   June 19, 2013, 07:08
Default Problem with sample and fieldAverage
Florian
Horus is on a distinguished road
Sorry the wrong subject, the problem is with forceCoeffs and fieldAverage, but I can't edit topic.
I use fieldAverage, reconstructPar the case and now I want to calculate forceCoeffs using the averaged values, but:
OpenFOAM 2.1x but I can switch to OF 2.2 if this is the problem.
Time = 8000
    Reading phi
    Reading U
    Reading p
Selecting incompressible transport model Newtonian
Selecting RAS turbulence model kOmegaSST
kOmegaSSTCoeffs
--> FOAM Warning :
    From function void forces::read(const dictionary&)
    in file forces/forces.C at line 309
    Could not find UMean, pMean in database.
    De-activating forces.
--> FOAM Warning :
--> FOAM Warning :
--> FOAM FATAL IO ERROR:
timeStepMean is not in enumeration:
2
outputTime
timeStep
file: /scratch/flindner/Car.Scoop6/system/controlDict::functions::coeffsRearWheelsAveraged::outputControl at line 137.
    From function NamedEnum<Enum, nEnum>::read(Istream&) const
    in file lnInclude/NamedEnum.C at line 72.
Well, but
$ ls 8000/
k.gz  nut.gz  omega.gz  p.gz  phi.gz  pMean.gz  U.gz  UMean.gz  uniform
I have also tried to comment out the fieldAverage function object from the controlDict.
What can the problem be here?
Thanks,
Florian
Horus is offline   Reply With Quote
Old   June 19, 2013, 09:25
Florian
A related problem I ran into is that I try to look up pMean from a piece of custom code:
    request for volScalarField pMean from objectRegistry region0 failed
    available objects of type volScalarField are
So it seems that somehow pMean und UMean are not registered to the database...
Any idea someone?
