2D vertical axis wind turbine, OpenFOAM beginner
Like Tree12Likes
Old   May 13, 2014, 01:35
Anand Lobo
Boloar is on a distinguished road
You are a bit more experienced than I am, in any case, lol.
I'd suggest starting a new thread on this (with details on what you have already achieved), as this was more for a beginner setup. I know users linnemann and wyldckat, among others on this forum, are also experienced and could help you more than I can.
Boloar is offline   Reply With Quote
Old   May 23, 2017, 01:12
Post Where I can find these?
  #22
Tulekk is on a distinguished road
Originally Posted by linnemann View Post
Hi
Here is the case used to produce the movie on Youtube.
https://dl.dropboxusercontent.com/u/...-TSR1.0.tar.gz
Best
Hello, I am sorry to bother in this old tread but I want to know, Where can I find these files? The link seems down. I am starting to learn this, doing the propeller and windmotion tutorials as Boloar said. And now I want to see how it works in those files. Could you please tell where else I can find them?
Tulekk is offline   Reply With Quote
Old   May 23, 2017, 02:39
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
Hi Dropbox removed all shared links.
Here is a working version.
https://www.dropbox.com/s/fyzpa1ycji....0.tar.gz?dl=0
Linnemann
PS. I do not do personal support, so please post in the forums.
linnemann is offline   Reply With Quote
Old   May 23, 2017, 12:05
Default Thank you :)
  #24
Thank you Linnemann, I really appreaciated. I will continue my learning and gonna try to help others like you did with me.
I just have a question about it. With the last openFoam version (4 and above), Can I work with sliding meshes without a problem? I read that they disable the function, and so one has to install the "foam extend" in order to use it? What do you know about that? I am asking this because I find it really odd that I cannot find this information anywhere. I just find people telling that they use extend foam to do this kind of work. And if they use open foam, it is a previous version, like around open Foam 2.1.
Anyway, I tried to run your case with openFoam 4.1 and with the foam extend 4.0 but I couldn't, I think it is because it is from a previous version, so maybe the format is different in some files.
Old   July 11, 2017, 11:20
王莹
Alisa_W is on a distinguished road
Originally Posted by Boloar View Post
Thanks, for the suggestion; I went and did that, but I'm still getting the same error it seems. No zero values in the initial conditions except in p.
So far I've used the mixerVesselAMI2D and propeller tutorials to try and figure out the AMI stuff. I've got the mesh correct now, but I might be confusing myself with those turbulence models. Gonna look over the wingMotion tutorials again and make sure I'm following that model correctly. Wish me luck.
Thanks!
Hello Boloar,
I met the same problem as your and I doubted whether it was due to the AMI? because the min AMI for the target face is 0?Could you please tell me how you solved your problem?
p.s. in my case the two interfaces can not match completely with one larger than the another.
Alisa_W is offline   Reply With Quote
Old   December 17, 2018, 16:04
Bram Kerkhofs1
brammekeuh987 is on a distinguished road
Hi Linneman
So I converted the old case which uses GGI to the version of OpenFOAM 1806 and I got it running but I see there are some 'strange' settings. I'm still fairly new to OF, so I'm curious why the settings are like this.
  • MaxCO=50
  • linear solver for pressure = PCG
So with this maxCo, the simulation wasn't stable after I converted it. Is there a reason why you've chosen it so large, and how do you keep it stable?
I read in most cases that GAMG is the best solver for your pressure. How come you took the PCG?
brammekeuh987 is offline   Reply With Quote
Old   April 23, 2021, 18:14
Icaro Torrres Parra
ikaruc is on a distinguished road
Hello Mr Niels,
Sorry for my bad English .
Can you share the case with a new link please , the one that is in the Forums it is not working . I want to use it to learn Openfoam for my thesis.
Thanks in advance for your help.
ikaruc is offline   Reply With Quote
Old   May 3, 2021, 07:18
linnemann's Avatar
Niels Nielsen
New links
https://www.dropbox.com/s/twl61ukf8t....0.tar.gz?dl=0
https://www.dropbox.com/s/fuxrngszgc....0.tar.gz?dl=0
AML likes this.
Linnemann
Old   November 9, 2021, 18:07
Edgar Alejandro Martínez Ojeda
Edgar Alejandro Martínez is on a distinguished road
I've a setup case using blockMesh: https://www.youtube.com/watch?v=fq3gYu-Ffx8
Edgar Alejandro Martínez is offline   Reply With Quote
Old   December 31, 2021, 15:02
Default Failed link Please introduce another link
  #30
alireza
alirez is on a distinguished road
Hi
Best
Hi dear linnemann.
I am a graduate student and I need to simulate a wind turbine in open foam to do my dissertation, thank you for your help in this regard.
alirez is offline   Reply With Quote
Old   January 17, 2022, 05:14
linnemann's Avatar
Niels Nielsen
New link to case
Tobi and AML like this.
Linnemann
vawt wind turbine, wind tunnel
[ICEM] Boundary conditions in copy-rotate 3-bladed vertical axis wind turbine pollenhavy ANSYS Meshing & Geometry 2 February 17, 2017 18:01
Wind turbine analyses in OF - first steps / beginner / cadcae OpenFOAM Running, Solving & CFD 3 March 1, 2015 17:00
Vertical axis wind turbine simulation vincentwks ANSYS 0 April 10, 2012 05:27
Vertical Axis Wind Turbine courtjester140 ANSYS 2 June 22, 2010 11:27
vertical axis wind turbines pyong Main CFD Forum 1 March 14, 2005 10:35
