forced convection of air inside a heated rectangular channel
Old   June 6, 2013, 03:59
T. Chourushi
Tushar@cfd is on a distinguished road
Well now,
Make the "p" BC zeroGradient instead of $calculated. Try to see if the result is coming..
Tushar@cfd is offline   Reply With Quote
Old   June 6, 2013, 04:01
Ank
ankur
Ank is on a distinguished road
I did the same..I changed calculated to zerogradient.
Tht error was from that only.
Ank is offline   Reply With Quote
Old   June 6, 2013, 05:03
T. Chourushi
If you wish then you can upload your complete case files here..
Like complete "/constant" directory with mesh.
Old   June 6, 2013, 05:20
Ank
ankur
Hey Tushar
I am not able to upload the mesh file. Can I send it to you by email or message?
Old   June 6, 2013, 05:30
T. Chourushi
Give me your email-id. I will contact you.
Old   June 6, 2013, 05:34
Ank
ankur
ankursingh59@gmail.com
Old   June 8, 2013, 07:45
Ank
ankur
Hey
I modified the simpleFoam solver and added T equation in it. It is also showing me the same problem as it was with buoyantBoussinesqSimpleFoam. The velocity is increasing from inlet to outlet. It is going from 1 m/s to 1.1 m/s. I tried it on pitzDaily tutorial but result was almost same and velocity peaked midway to 10.99 m/s (should be 10 m/s) and then decreased. I am not able to get after adding T what is the problem it is having.
Any suggestions?
Old   June 11, 2013, 09:36
Fabian Roesler
fabian_roesler is on a distinguished road
Hi Ank
you have a quite orthogonal mesh. So you could just switch the snGradScheme back to uncorrected and use this for the laplacian schemes as well. Moreover, for the epsilon, omega and R divSchemes you could use a linear interpolation scheme instead the diffusive first order upwind.
Have you tried a momentum predictor step or changed all upwind to linearUpwind schemes?
Best regards
Fabian
  ddtSchemes
      default         Euler;
  gradSchemes
      default         leastSquares;
  divSchemes
      default         none;
      div(phi,U)      Gauss linearUpwindV grad(U);
      div(phi,T)      Gauss linearUpwind grad(T);
      div(phi,k)      Gauss linear;
      div(phi,epsilon) Gauss linear;
      div(phi,omega) Gauss linear;
      div(phi,R)      Gauss linear;
      div(R)          Gauss linear;
      div((nuEff*dev(T(grad(U))))) Gauss linear;
  laplacianSchemes
      default         none;
      laplacian(nuEff,U) Gauss linear uncorrected;
      laplacian(Dp,p_rgh) Gauss linear uncorrected;
      laplacian(kappaEff,T) Gauss linear uncorrected;
      laplacian(DkEff,k) Gauss linear uncorrected;
      laplacian(DepsilonEff,epsilon) Gauss linear uncorrected;
      laplacian(DepsilonEff,omega) Gauss linear uncorrected;
      laplacian(DomegaEff,omega) Gauss linear uncorrected;
      laplacian(DREff,R) Gauss linear uncorrected;
  interpolationSchemes
      default         linear;
  snGradSchemes
      default         uncorrected;
  fluxRequired
      default         yes;
      p_rgh              ;
fabian_roesler is offline   Reply With Quote
Old   June 11, 2013, 09:43
Default Transient Simple?
  #29
Fabian Roesler
Hi Ank
one more question. You say you use a SIMPLE solver, no matter which exactly. But you have a ddtScheme in your fvSchemes dictionary. Do you have a kind of transient SIMPLE solver? Could it just be that your results did not jet converge for steady-state solution? If you want steady-state, try to increase your number of time steps.
Regards
Fabian
Old   June 11, 2013, 09:46
Ank
ankur
Hey Fabian
Thanks for your reply.
These suggestions are really good. But the problem was rather simple and has been solved. The increase in the velocity near the outlet was because velocity decreases near the wall along the length (boundary layer development). So to maintain a mass balance it increases near the centre of the outlet. And I am using steady state only, I don't have any transient SIMPLE solver. I have corrected that ddtScheme also to steady state.
Thanks and I will incorporate your suggestions also.
Old   September 25, 2013, 02:30
Srivathsan N
Sherlock_1812 is on a distinguished road
Hi Ankur,
What changes did you finally make to the 0/p and 0/p_rgh directory?
Regards,
Srivaths
Sherlock_1812 is offline   Reply With Quote
Old   September 25, 2013, 07:41
Ank
ankur
Hey Srivathsan,
I am attaching my p and p_rgh files. It works well, you can have a look at it.
p file:
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
inlet
type calculated;
value $internalField;
tube
type calculated;
outlet
type calculated;
wall
type calculated;
fin
type calculated;
symmetry
type symmetryPlane;
p_rgh file :
| \\ / O peration | Version: 2.2.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
object p;
boundaryField
inlet
type zeroGradient;
outlet
type fixedValue;
value uniform 0;
wall
type zeroGradient;
tube
type zeroGradient;
fin
type zeroGradient;
symmetry
type symmetryPlane;
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 08:59
Creating a grid for a channel inside a brick sanin FLUENT 0 November 6, 2008 09:03
how to estimage air speed with natural convection? Pei-Ying Hsieh Main CFD Forum 2 May 1, 2008 16:29
Modelling the Heat flow inside the curing oven Marios Vlad CFX 1 February 6, 2008 08:11
CFX-5.5 simulating air free convection Dustin Lee CFX 0 April 16, 2003 03:54
