May 20, 2013, 06:37 |
Can't import mesh to discretizer !!!
Tachakorn
Rep Power: 13 |
May 20, 2013, 09:34 |
Nima Samkhaniani
Rep Power: 25 |
your question is too general, let us to be more specific
1- where is your mesh? ( is it in OpenFOAM test case directory?) 2- how did you create it?
My Personal Website (http://nimasamkhaniani.ir/) Telegram channel (https://t.me/cfd_foam) |
May 22, 2013, 03:34 |
Tachakorn
Rep Power: 13 |
1) my mesh is in "discretizer" folder
2) I did this mesh form Gambit 2.4.6 |
May 22, 2013, 14:27 |
Nima Samkhaniani
Rep Power: 25 |
i feel it should be in test case directory, beside 0, constant and system folder
May 23, 2013, 05:43 |
Tachakorn
Rep Power: 13 |
First of all, when it showed "error" but discretizer created constant and system folder to my location,but not have "0" folder
My mesh is "1.msh" . and I must put 1.msh to test case directory ??? and where is test case directory ??? I 'm very confuse How i solve this problem ??? T^T |
May 23, 2013, 09:59 |
Nima Samkhaniani
Rep Power: 25 |
copy one of OpenFOAM tutorials for example cavity and put your mesh beside 0, constant and system
then try to import it
May 28, 2013, 04:46 |
Tachakorn
Rep Power: 13 |
I copied folder 0,constant and system to my mesh folder.
but the result was the same. What's Happened to me !!! T^T |
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 08:34 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 10:03 |
Unable to import mesh on the CFX-Pre | jarrai | CFX | 1 | December 20, 2010 08:05 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 20:43 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
