Simulations Flow 3D over Flat plate
Old   May 3, 2013, 06:04
Default Simulations Flow 3D over Flat plate
DANG QUOC BAO
baoaero is on a distinguished road
Hi all,
I am new user using OpenFoam,. I am making simulation flow steady over the flat plate 3D with dim ( c =0.2 m and l=0.7 m). What solver can i use for solving this proplem. I had tried many time but had many errors. I want to calculate the lift, drag cofficient on the flat plate but i don't know how do it? I wish i have help me for solving this proplem from all members of CFD online.
Thank you so much..
baoaero is offline   Reply With Quote
Old   May 4, 2013, 08:23
fumiya's Avatar
Fumiya Nozaki
fumiya is on a distinguished road
For the steady simulations of incompressible, turbulent flow, you can use simpleFoam solver.
For the steady simulations of compressible, turbulent flow, you can use rhoSimpleFoam solver.
You can use the forceCoeffs function object to calculate the force coefficients.
and find the information about how to use it by doing the motorBike tutorial.
Best regards,
Fumiya
fumiya is offline   Reply With Quote
Old   May 9, 2013, 05:56
DANG QUOC BAO
Dear Fumiya
I had done this proplem along your intructions and had result Cm 8.27999e-05 Cd 0.000173674 Cl 0.00082136. Conditions of Promblem: velocity inlet 1 m/s, nutida 0.001 at inlet and Zerogradient at other boundary, pressure equal 0 at outlet and ZeroGradient at outlet. At wall (flat plate) fix value
(0,0,0) velocity and Pressure is zeroGradient. Dimmentions of flat plate (0.4mx1mX0.01m). Model mesh 220.000 point.
I dont have much experience in CFD Calculations, I don't know that is Result is good or bad ? I dont know edit where part of problem for having good result?
Would you mind help solve this proplem? I am do my thesis for graduate university. With project "Simulation flow over Propeller". very difficult.
I wish i have your help.
Thank you very much.
Best regards,
Boundary condition
p
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
wall
type zeroGradient;
symmetry
type symmetryPlane;
inlet
type fixedValue;
value uniform 0;
outlet
type fixedValue;
value uniform 0;
U
dimensions [0 1 -1 0 0 0 0];
internalField uniform (1 0 0);
boundaryField
wall
type fixedValue;
value uniform (0 0 0);
symmetry
type symmetryPlane;
inlet
type fixedValue;
value uniform (1 0 0);
outlet
type zeroGradient;
nuTida
dimensions [0 2 -1 0 0 0 0];
internalField uniform 0.001;
boundaryField
wall
type zeroGradient;
symmetry
type symmetryPlane;
inlet
type fixedValue;
value uniform 0.001;
outlet
type zeroGradient;
nut
boundaryField
wall
type zeroGradient;
symmetry
type symmetryPlane;
inlet
type fixedValue;
outlet
type zeroGradient;
Old   May 13, 2013, 22:43
DANG QUOC BAO
Dear all
who are you help me solve this Problem...It very difficult. I try many time but not success....I wish you can help me....
Thanks a lot...
Bao
Old   May 14, 2013, 03:52
HECKMANN Frédéric
fredo490 is on a distinguished road
For a speed of 1m/s you can use simpleFoam (steady state, incompressible sover). With a very fine mesh (y+ of less than 1), you can use k-omega SST that will give you the best boundary layer solution.
If you don't know much about OpenFoam, you can try http://www.sim-flow.com/#
It is an "automatic" way to generate an OpenFoam case. Then you can study the files and try to understand the settings.
fredo490 is offline   Reply With Quote
Old   May 15, 2013, 01:10
DANG QUOC BAO
Dear all
I had done download simFlow sonfware. But i can not install into Unbutu 12.04LS (32bit). Would you mind can help me for install simFlow. I had done follow indtructions on website www.simFlow.com but not success because i can not run the file install after finishing dowload. (i tried many tiem but it was not run). I had check "Allow executing files as program" after double clik on file and IT NOT RUN.
I wish you can help me install SimFlow for studing in University? Thanks a lot...i glad to you...
Bao
Old   May 15, 2013, 09:23
JR22's Avatar
Jose Rey
JR22 will become famous soon enough
I tried SimFlow, and the Windows version worked for me, the Ubuntu/Linux one didn't. Try contacting their support staff as it is a Beta and they are likely trying to figure out what goes wrong. Give them as much information as you can (i.e., your system details, the steps to reproduce your problem, and whatever logs or error messages that are appropriate).
JR22 is offline   Reply With Quote
Old   June 7, 2013, 06:53
Aneta
AnetaC is on a distinguished road
Dear DANG QUOC BAO,
please check FAQ and Q&A on www.sim-flow.com, there you will undoubtedly find the solution to your problem.
AnetaC is offline   Reply With Quote
flat plated
CFD by anderson, chp 10.... supersonic flow over flat plate varunjain89 Main CFD Forum 18 May 11, 2018 08:31
Low Reynolds Number Flow over a Flat Plate Go FLUENT 4 August 28, 2013 06:19
Validating OF, turbulent flow over flat plate Thilo OpenFOAM Verification & Validation 0 July 3, 2012 06:29
Experimental paper for flow over flat plate Sid Main CFD Forum 3 October 8, 2008 12:45
results for flow past flat plate normal to flow lisa Main CFD Forum 2 August 30, 2005 17:36
