April 12, 2013, 10:48 |
Stripes close to my Inlet BC in OpenFOAM
Joachim
Rep Power: 15 |
Hello everyone!
I am trying to simulate the flow over a laminar flat plate (1 meter long). I am using standard values for the air (nothing crazy...), and a velocity of 0.1 m/s (solver -> icoFoam). I only have one problem: the flow close to the inlet boundary is really strange, as can be seen in the attached figure. I thought this would be due to my boundary conditions, so I tried different types: fixedValue / inletOutlet / pressureInletVelocity and pressureInletOutletVelocity. Nothing worked! I always have these stripes on the left (except in the pressureInletVelocity case, where the stripes disappear, but the velocity is clearly wrong in the tangential direction. It increases linearly with distance from the bottom plane over the whole domain). I also tried to modify the outlet and top boundaries, but nothing worked! Would anyone have an idea on how to solve this problem? I would be extremely grateful! Thank you very much, Joachim |
April 12, 2013, 21:55 |
Fumiya Nozaki
Rep Power: 19 |
What scheme do you use for the convection term?
I think the setting "div(phi,U) Gauss linear" could be the cause of the problem. P.S. You might want to try the simpleFoam solver for steady simulations. Best regards, Fumiya |
April 17, 2013, 12:54 |
Joachim
Rep Power: 15 |
Oh sorry, it seems that I posted this thread at the wrong place.
Thank you for your answer. I modified the discretization scheme for the divergence term, but nothing changed. As you suggested, I used simpleFoam instead of icoFoam, and everything worked just fine. This is strange, I thought that unsteady simulations were inherently more stable than steady simulations... |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
How to set up the inlet boundary condition for a low pressure case? | beastieboys6 | FLUENT | 3 | April 10, 2012 22:46 |
OpenFOAM Training in Europe and USA | hjasak | OpenFOAM | 0 | August 8, 2008 05:33 |
Adventure of fisrst openfoam installation on Ubuntu 710 | jussi | OpenFOAM Installation | 0 | April 24, 2008 14:25 |
Inlet BC OpenFOAM 12 | ghanshyam | OpenFOAM Running, Solving & CFD | 7 | August 30, 2005 07:44 |
