April 10, 2013, 05:19 |
shockTube tutorial
Gnosis Zhou
Rep Power: 13 |
I am having problems with the shockTube tutorial. I just entered the corresponding shockTube folder, created the mesh with "blockMesh" and entered the command line "rhoCentralFoam" and then the terminal showed the following error messages: --> FOAM Warning : From function polyBoundaryMesh::groupPatchIDs() const in file meshes/polyMesh/polyBoundaryMesh/polyBoundaryMesh.C at line 474 Patch empty specifies a group empty which is also a patch name. This might give problems later on. #0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam220/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam220/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #2 Uninterpreted: #3 Foam::heThermo<Foam::psiThermo, Foam::pureMixture<Foam::constTransport<Foam::speci es::thermo<Foam::hConstThermo<Foam::perfectGas<Foa m::specie> >, Foam::sensibleInternalEnergy> > > >::init() in "/opt/openfoam220/platforms/linuxGccDPOpt/lib/libfluidThermophysicalModels.so" #4 Foam::heThermo<Foam::psiThermo, Foam::pureMixture<Foam::constTransport<Foam::speci es::thermo<Foam::hConstThermo<Foam::perfectGas<Foa m::specie> >, Foam::sensibleInternalEnergy> > > >::heThermo(Foam::fvMesh const&, Foam::word const&) in "/opt/openfoam220/platforms/linuxGccDPOpt/lib/libfluidThermophysicalModels.so" #5 Foam::psiThermo::addfvMeshConstructorToTable<Foam: :hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::constTransport<Foam::speci es::thermo<Foam::hConstThermo<Foam::perfectGas<Foa m::specie> >, Foam::sensibleInternalEnergy> > > > >::New(Foam::fvMesh const&, Foam::word const&) in "/opt/openfoam220/platforms/linuxGccDPOpt/lib/libfluidThermophysicalModels.so" #6 Foam::autoPtr<Foam::psiThermo> Foam::basicThermo::New<Foam::psiThermo>(Foam::fvMe sh const&, Foam::word const&) in "/opt/openfoam220/platforms/linuxGccDPOpt/lib/libfluidThermophysicalModels.so" #7 Foam::psiThermo::New(Foam::fvMesh const&, Foam::word const&) in "/opt/openfoam220/platforms/linuxGccDPOpt/lib/libfluidThermophysicalModels.so" #8 in "/opt/openfoam220/platforms/linuxGccDPOpt/bin/rhoCentralFoam" #9 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6" #10 in "/opt/openfoam220/platforms/linuxGccDPOpt/bin/rhoCentralFoam" I do not understand what happened to this tutorial? Could somebody help me? |
September 5, 2013, 09:30 |
Wenfu Wei
Hi, have you execute the "setFields" command before the "rhoCentralFoam" ?
September 5, 2013, 09:45 |
Gnosis Zhou
Rep Power: 13 |
Problem on Fluent Tutorial: Horizontal Film Boilig | Feng | FLUENT | 2 | April 13, 2013 06:34 |
ShockTube tutorial modification | cts | OpenFOAM Running, Solving & CFD | 1 | January 15, 2013 16:03 |
[Virtualization] OpenFOAM oriented tutorial on using VMware Player - support thread | wyldckat | OpenFOAM Installation | 2 | July 11, 2012 17:01 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 04:52 |
Rotor/stator tutorial, and how to... | gilberto | CFX | 5 | January 21, 2002 10:41 |
