run openfoam with bash script
Old   March 25, 2013, 12:47
Default run openfoam with bash script
Gosi
hi everybody,
i wrote a short Fluent3DMeshtoFoam bash script.
#!/bin/sh
/sw/ansys/ansys12.1/v121/fluent/bin/fluent 3ddp -g < fluent_ascii
fluent3DMeshToFoam recalculation_re=200k_done_ascii.cas
createPatch
rm -r /home/stswi1/HiWi/OpenFOAM/8k5/constant/polyMesh
cp -a /home/stswi1/HiWi/OpenFOAM/8k5/70.02/polyMesh* /home/stswi1/HiWi/OpenFOAM/8k5/constant/
rm -r /home/stswi1/HiWi/OpenFOAM/8k5/70.02
/sw/OpenFOAM/OpenFOAM-1.7.x/applications/bin/linux64GccDPOpt/rhoSimpleFoam
wallGradT
it works when i run openfoam (option openfoam-17.x) and then run the bash script.
without running openfoam at first the following fault appears.
/sw/OpenFOAM/OpenFOAM-1.7.x/applications/bin/linux64GccDPOpt/rhoSimpleFoam: symbol lookup error: /sw/OpenFOAM/OpenFOAM-1.7.x/applications/bin/linux64GccDPOpt/rhoSimpleFoam: undefined symbol: _ZN4Foam13fvsPatchFieldINS_6VectorIdEEE28disallowD efaultFvsPatchFieldE
is it something with the environment variables?
could anybody help me?
thanks in advance. Simon
Old   March 25, 2013, 17:23
Retired Super Moderator
Bruno Santos
Greetings Simon and welcome to the forum!
I'll have to be quick to answer:
  1. I can only assume that the "openfoam" command you're talking about is a command specifically designed for loading OpenFOAM's shell variables.
  2. For more on this topic, read: Advanced tips for working with the OpenFOAM shell environment
Best regards,
Bruno
Old   April 11, 2013, 10:10
Gosi
hi bruno,
thanks for your quick response.
yes the "openfoam" command i am talking about is a command for loading OpenFOAM's shell variables.
i will take a look at your link.
simon
Would you pay to run your OpenFoam simulations remotely? danhumphreys OpenFOAM 4 October 27, 2010 14:00
Can't run paraFoam with OpenFOAM 1.6 Fed11 OpenFOAM Installation 1 October 30, 2009 20:54
Modified OpenFOAM Forum Structure and New Mailing-List pete Site News & Announcements 0 June 29, 2009 06:56
OpenFOAM Debian packaging current status problems and TODOs oseen OpenFOAM Installation 9 August 26, 2007 14:50
How to run the graphic interface of openfoam liugx212 OpenFOAM Running, Solving & CFD 3 November 12, 2005 16:06
