motionU file
Old   March 15, 2013, 13:19
Default motionU file
Sasan Ghomi
sasanghomi is on a distinguished road
Hi foamers ,
What is motionU file ?? I think it used for cases with dynamic mesh.....
My second question is about componentMixed type that used for the piston in the below motionU file..what is componentMixed type ??what is ref value and value fraction???
| \\      /  F ield         | OpenFOAM Extend Project: Open source CFD        |
|  \\    /   O peration     | Version:  1.6-ext                               |
|   \\  /    A nd           | Web:      www.extend-project.de                 |
FoamFile
    version     2.0;
    format      ascii;
    class       tetPointVectorField;
    location    "0";
    object      motionU;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    piston
        type            componentMixed;
        refValue        uniform (0 0 0);
        valueFraction   uniform (0 0 1);
    liner
        valueFraction   uniform (1 1 0);
    cylinderHead
        type            fixedValue;
        value           uniform (0 0 0);
    intakePort
        type            fixedValue;
    presin
        type            fixedValue;
    exhaustPort
        type            fixedValue;
    presout
        type            fixedValue;
    valveCurtainCyl1
    valve1
        type            fixedValue;
    valve2
        type            fixedValue;
    valveCurtainPort1
        type            zeroGradient;
    valveDetachCyl1
        type            zeroGradient;
    valveDetachPort1
        type            zeroGradient;
    valveCurtainCyl2
    valve3
        type            fixedValue;
    valve4
        type            fixedValue;
    valveCurtainPort2
        type            zeroGradient;
    valveDetachCyl2
        type            zeroGradient;
    valveDetachPort2
        type            zeroGradient;
    defaultFaces
        type            empty;
Thanks and best regards,
Sasan.
sasanghomi is offline   Reply With Quote
Old   March 21, 2013, 03:30
Sasan Ghomi
I appreciate any help.....
Old   March 21, 2013, 03:41
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Sasan,
The motionU file is related to the laplaceFace-/laplaceCellDecomposition methods, which are only available in OF16-ext. In This file you specify the behaviour of/boundary conditions for the mesh motion.
With respect to the component mixed, then the refValue and valueFraction are specific information needed by this boundary condition. I made a quick search in the source code, however, I cannot figure out what it is doing/which class it is derived from.
Good luck,
Niels
ngj is offline   Reply With Quote
Old   March 21, 2013, 05:31
Sasan Ghomi
Hi Niels ,
thank you very much.
Sasan.
Old   April 11, 2013, 11:25
Sasan Ghomi
Hi Niels ,
Can you explain when I should use componentMixed and in this type which direction should be 1 and which one should be 0 ???(for example uniform (1 1 0) )
Actually the motionU file that I attached above is related a 2D engine simulation and I changed the geometry and I created a 3D engine and I want to know what are the boundary conditions in motionU that I must change them?
Sasan.
[swak4Foam] difficulties installing swak4foam newbie29 OpenFOAM Community Contributions 120 October 21, 2022 05:01
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 12:44
1.7.x Environment Variables on Linux 10.04 rasma OpenFOAM Installation 9 July 30, 2010 05:43
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 12:46
