What hardware are you using? Tips for new user?
Old   March 15, 2013, 10:55
Default What hardware are you using? Tips for new user?
Steve
greenleader is on a distinguished road
There is not not much discussion about hardware on the OpenFOAM forum
I am currently playing with OF in a virtual machine under XP on an oldish Intel Core-duo E6300, but I plan to move to new hardware soon.
I don't know a lot about computer hardware - my questions are:
- should I go for a single or dual processor system? (can I run on one processor and then add another later if I wanted more power?)
- what processors are recommended?
- are there any brands/processors etc that one should avoid for compatibility reasons?
- whats important when buying RAM (apart from the size)? I think I'd start with 16GB but select a system that I could expand to say 32GB if I wanted to later.
I am starting out with 2D problems with less than 100,000 cells but when I build up to 3D geometry I expect 5M cells is likely.
regards
Steve
greenleader is offline   Reply With Quote
Old   March 15, 2013, 15:12
Elvis
elvis will become famous soon enough
the Hardware forum at cfd-online is not bad and there are also people discussing
on hardware that is suitable for OF, but the discussion for other software can be read as well
because the ratio 'cells/CPU" is important. I think you do not see a acceleration below 200000 cells/CPU.
Intel CPU's have better performance than AMD in this area. Some people & companies have worked on GPU acceleration for OF. You find announcements in this forum and presentations @ OF-workshop
elvis is offline   Reply With Quote
Old   March 16, 2013, 10:42
Steve
thanks for pointing that out - I was focused on the openFoam forum and I had not looked in the more general forum. I have now found some useful tips...
Old   March 19, 2013, 13:04
Kent Wardle
kwardle is on a distinguished road
I would disagree somewhat with what Elvis has said regarding cells/CPU. While it is very dependent on the physics you are looking at, for interFoam based VOF solvers I have found you can get good speedup at much higher per processor distributions (~25K cells/proc). Maybe you had an extra "0"? That has been my experience anyway. And if you are very impatient and not computational resource limited, I sometimes run even lower (7500K cells/core), but this is very aggressive and about the limit where you don't get much more speed-up and start to drop below 75% parallel efficiency. This is for multiphaseEulerFoam anyway. Just my 2 cents.
kwardle is offline   Reply With Quote
Old   August 1, 2013, 09:21
immortality's Avatar
Ehsan
immortality is on a distinguished road
hi
What do you mean by acceleration originated by "cells/CPU"?could anyone clarify more in this relation?
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Check particle impaction with User Fortran Julian K. CFX 3 January 12, 2012 10:46
collect User Experience about CFD softwares dxw_CFD Main CFD Forum 12 October 24, 2011 23:08
user routine, user funcion, or fortran compile effect on the memroy? princeps11 CFX 1 May 13, 2009 19:37
particle user routines Felix CFX 1 July 24, 2006 13:32
USA user conferences 2003 CD adapco Group Marketing Siemens 0 April 11, 2003 12:45
