valveDetachCyl &valveDetachPort in the boundary file |
March 9, 2013, 20:28 |
Sasan Ghomi
Rep Power: 15 |
Dear foamers ,
I am simulating an engine with sonicTurbDyMEngineFoam and simpleEngineTopoFVmesh library.... In a 2D case that mesh generated by using blockMesh there are two boundaries (valveDetachCyl &valveDetachPort) that they dont have any faces in blockMeshDict file....This will lead to creat this boundaries in the boundary file in the polymesh directory... My problem comes when I generate the mesh by using Gambit... when I use fluentMeshToFoam this will lead to creat boundary file and I cant add a new boundary face manually in the boundary file because I dont know startFace... please anyone help me? existing of these boundaries in the boundary file (polymesh/boundary) is necessary? Code:
// The FOAM Project // File: blockMeshDict /* ------------------------------------------------------------------------------- ========= | dictionary \\ / | \\ / | Name: blockMeshDict \\ / | Family: FoamX configuration file \\/ | F ield | FOAM version: 2.2 O peration | Product of Nabla Ltd. A and | M anipulation | Email: Enquiries@Nabla.co.uk ------------------------------------------------------------------------------- */ // FoamX Case Dictionary. FoamFile { version 2.0; format ascii; root "/home/warhol/chris/foam/chris2.2/run/tutorials/icoFoam"; case "cavity"; instance "constant/polyMesh"; local ""; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // ORIGINAL BLOCKMESH BUT WITH MORE AND SMALLER CELLS (blockMesh_Orig) convertToMeters 0.01; vertices ( // Left bank and centre block, back (1 0.25 0) //0 (-1 0.25 0) //1 (-1 0.25 0) //2 (-1.5 0.25 0) //3 (-3.5 0.25 0) //4 (-4 0.25 0) //5 (-4 0.25 0) //6 (-5 0.25 0) //7 (-1 0.25 -0.3) //8 (-1.5 0.25 -0.3) //9 (-3.5 0.25 -0.3) //10 (-4 0.25 -0.3) //11 (-1 0.25 -0.75) //12 (-4 0.25 -0.75) //13 (1 0.25 -1) //14 (-1 0.25 -1) //15 (-1 0.25 -1) //16 (-4 0.25 -1) //17 (-4 0.25 -1) //18 (-5 0.25 -1) //19 (-1.5 0.25 3) //20 (-3.5 0.25 3) //21 // Left bank and centre block, front (1 -0.25 0) //22 (-1 -0.25 0) //23 (-1 -0.25 0) //24 (-1.5 -0.25 0) //25 (-3.5 -0.25 0) //26 (-4 -0.25 0) //27 (-4 -0.25 0) //28 (-5 -0.25 0) //29 (-1 -0.25 -0.3) //30 (-1.5 -0.25 -0.3) //31 (-3.5 -0.25 -0.3) //32 (-4 -0.25 -0.3) //33 (-1 -0.25 -0.75) //34 (-4 -0.25 -0.75) //35 (1 -0.25 -1) //36 (-1 -0.25 -1) //37 (-1 -0.25 -1) //38 (-4 -0.25 -1) //39 (-4 -0.25 -1) //40 (-5 -0.25 -1) //41 (-1.5 -0.25 3) //42 (-3.5 -0.25 3) //43 // Right bank, back (1 0.25 0) //44 (1.5 0.25 0) //45 (3.5 0.25 0) //46 (4 0.25 0) //47 (4 0.25 0) //48 (5 0.25 0) //49 (1 0.25 -0.3) //50 (1.5 0.25 -0.3) //51 (3.5 0.25 -0.3) //52 (4 0.25 -0.3) //53 (1 0.25 -0.75) //54 (4 0.25 -0.75) //55 (1 0.25 -1) //56 (4 0.25 -1) //57 (4 0.25 -1) //58 (5 0.25 -1) //59 (1.5 0.25 3) //60 (3.5 0.25 3) //61 // Right bank, front (1 -0.25 0) //62 (1.5 -0.25 0) //63 (3.5 -0.25 0) //64 (4 -0.25 0) //65 (4 -0.25 0) //66 (5 -0.25 0) //67 (1 -0.25 -0.3) //68 (1.5 -0.25 -0.3) //69 (3.5 -0.25 -0.3) //70 (4 -0.25 -0.3) //71 (1 -0.25 -0.75) //72 (4 -0.25 -0.75) //73 (1 -0.25 -1) //74 (4 -0.25 -1) //75 (4 -0.25 -1) //76 (5 -0.25 -1) //77 (1.5 -0.25 3) //78 (3.5 -0.25 3) //79 ); blocks ( // Centre block hex (0 1 15 14 22 23 37 36) (20 20 1) simpleGrading (1 1 1) // Left bank hex (6 7 19 18 28 29 41 40) (20 20 1) simpleGrading (1 1 1) //a hex (12 13 17 16 34 35 39 38) (20 5 1) simpleGrading (1 1 1) //b hex (20 21 4 3 42 43 26 25) (20 24 1) simpleGrading (1 1 1) //c hex (2 3 9 8 24 25 31 30) (8 6 1) simpleGrading (1 1 1) //d hex (3 4 10 9 25 26 32 31) (20 6 1) simpleGrading (1 1 1) //e hex (4 5 11 10 26 27 33 32) (8 6 1) simpleGrading (1 1 1) //f // Right bank hex (49 48 58 59 67 66 76 77) (20 20 1) simpleGrading (1 1 1) //g hex (55 54 56 57 73 72 74 75) (20 5 1) simpleGrading (1 1 1) //h hex (61 60 45 46 79 78 63 64) (20 24 1) simpleGrading (1 1 1) //i hex (47 46 52 53 65 64 70 71) (8 6 1) simpleGrading (1 1 1) //j hex (46 45 51 52 64 63 69 70) (20 6 1) simpleGrading (1 1 1) //k hex (45 44 50 51 63 62 68 69) (8 6 1) simpleGrading (1 1 1) //l ); edges ( ); patches ( wall piston ( (14 36 37 15) (16 38 39 17) (18 40 41 19) (57 75 74 56) (59 77 76 58) ) wall liner ( (7 19 41 29) (59 49 67 77) ) wall cylinderHead ( (0 1 23 22) (2 3 25 24) (4 5 27 26) (6 7 29 28) (45 44 62 63) (47 46 64 65) (49 48 66 67) ) wall intakePort ( (20 42 25 3) (21 4 26 43) ) wall presin ( (20 21 43 42) ) wall exhaustPort ( (60 45 63 78) (61 79 64 46) ) wall presout ( (60 78 79 61) ) wall valveCurtainCyl1 ( (1 15 37 23) (6 28 40 18) ) wall valve1 // bottom ( (12 34 35 13) ) wall valve2 // top ( (8 30 31 9) (9 31 32 10) (10 32 33 11) ) wall valveCurtainPort1 ( (2 24 30 8) (12 34 38 16) (5 11 33 27) (13 17 39 35) ) wall valveDetachCyl1 () wall valveDetachPort1 () wall valveCurtainCyl2 ( (0 22 36 14) (48 58 76 66) ) wall valve3 // bottom ( (55 73 72 54) ) wall valve4 // top ( (53 71 70 52) (52 70 69 51) (51 69 68 50) ) wall valveCurtainPort2 ( (44 50 68 62) (54 56 74 72) (47 65 71 53) (55 73 75 57) ) wall valveDetachCyl2 () wall valveDetachPort2 () ); mergePatchPairs ( ); // ************************************************************************* // Sasan. Last edited by sasanghomi; March 10, 2013 at 06:35. |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 18:22 |
[swak4Foam] problem on installing swak4Foam | navid2 | OpenFOAM Community Contributions | 2 | May 30, 2012 05:32 |
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' | mfiandor | OpenFOAM Installation | 2 | January 25, 2010 10:50 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 11:23 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 18:51 |
