March 5, 2013, 12:11 |
Questions about simplefoam
Mao Mao
Hi all,
I am relatively new to OpenFOAM and I have a question about the solver simpleFoam. I am using OF 2.1.1. I read a little bit about the solver and algorithm and had some understanding of it. One thing confuses me though. In the source code of simpleFoam UEqn.H "tmp<fvVectorMatrix> UEqn ( fvm::div(phi, U) + turbulence->divDevReff(U) == sources(U) ); UEqn().relax(); sources.constrain(UEqn()); solve(UEqn() == -fvc::grad(p));" why is there a "sources(U)" term in the UEqn and it is even a function of U? And what is "sources.constrain(UEqn())" for? Any help will be appreciated. |
March 6, 2013, 02:16 |
Mahdi Hosseinali
Rep Power: 18 |
Digging it in doxygen you first get to IObasicSourceList which is a derivative of IOdictionary and basicSourceList. In latter you find operator() and constraint function:
http://foam.sourceforge.net/docs/cpp/a00081.html However in operator() code addSup does nothing according to: Foam::basicSource::addSup In case it was set to something else constraint clips it in a defined range. |
interFoam vs. simpleFoam channel flow comparison | DanM | OpenFOAM Running, Solving & CFD | 12 | January 31, 2020 15:26 |
Laminar simpleFoam and inviscid simpleFoam | herenger | OpenFOAM Running, Solving & CFD | 7 | July 11, 2013 06:27 |
Trying to run a benchmark case with simpleFoam | spsb | OpenFOAM | 3 | February 24, 2012 09:07 |
Naca0012 k-e mpirun gives fpe whereas simpleFoam not | Pierpaolo | OpenFOAM | 1 | May 8, 2010 03:08 |
Error running simpleFoam in parallel | skabilan | OpenFOAM Running, Solving & CFD | 2 | August 29, 2008 09:42 |
