March 4, 2013, 18:42 |
High nuSGS value in periodic hill case
j.t.
Rep Power: 13 |
Hello Foamers,
I am work on the 2D periodic hill test case using channelFOam , validated by Ercoftac, http://qnet-ercoftac.cfms.org.uk/w/i...3-30_Test_Case My problem is I get good profile for <U>,<V>,<u'u'>, <v'v'>,<w'w'> etc. but the magnitude of all these value are high i.e. the shape of the curve is good compared to the result in above link, but the numerical values overshoot. the BIGGEST problem, is I get very high values of nuSgs during the simulation, and the profile does not look very reasonable too. I have 1) USed a very fine grid - 4.7 million cells, - I know for sure that mesh is good since it was used in mnay previous journals with good result. 2) For initial condition: I built coarse mesh (450,000 cells) and averaged it for 200 flo through times, and interpolated the mean U field values to the fine mesh using mapFields 3) Attached the picture of my nuSGs at x/h = 4 axial distance. subgrid viscosity cannot be this high right? the nuSgs value for the coarse (initial field) mesh was high like this too, but I thought that was due to poor mesh resolution near wall. but here its fine mesh, how is this hapening? I mapFields only the U file, to the fine mesh and not the others. Please offer help... I have real no idea why this is happening. Additional detial: Re = 10595 So based on Re and hill height of h = 28 mm, I calculate incoming bulk velocity as 7.56 m/s. In channelFoam transportProperties my Ubar is (7.56 0 0) Thank you all... I thank your help very much. j.t Last edited by turbfoam; March 6, 2013 at 01:21. Reason: Added additional detial |
Periodic boundary condition | Arif | FLUENT | 3 | March 9, 2017 01:18 |
Must periodic oscillation give periodic results? | zonexo | Main CFD Forum | 6 | May 13, 2007 15:36 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
Turbulent Flat Plate Validation Case | Jonas Larsson | Main CFD Forum | 0 | April 2, 2004 10:25 |
Body force - Does it work? | Jan Rusås | CFX | 5 | August 27, 2002 09:50 |
