February 21, 2013, 16:17 |
rotating plate in icoFoam
Pengchuan Wang
Rep Power: 13 |
Hello everyone,
I'm really new to OpenFOAM. I tried to simulate a plate that rotates relatively to another stationary plate. The picture is in attachment.(I don't know how to insert a picture here. Sorry about that). I used icoFoam and everything seemed OK. Then I changed the rotating plate to another shape which has some grooves on it. Then the rotatingwall boundary failed. I searched the internet and found I needed to use rotating reference frame. But there are all turbulent solvers. and my problem is a laminar flow. Can someone teach me how to do this? Thank you very much. |
February 21, 2013, 17:32 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings pechwang,
Turbulent solvers usually have an option for turning off said turbulence! If I remember correctly, it should be as simple as:
Bruno
February 25, 2013, 10:44 |
#3 | |
Pengchuan Wang
Rep Power: 13 |
Hi Bruno,
Thank you for your reply. I have another question, since I turn off the turbulence, do I still need to define seven initial conditions for it? I think for a laminar flow it just need P and U. Is that right? Thank you again. Pengchuan Quote:
February 25, 2013, 17:14 |
Bruno Santos
Rep Power: 128 |
Hi Pengchuan,
It's as easy as doing some trial-and-error If you remove all of the files from the "0" folder, except for "p" and "U", the solver will complain if there is a file missing! Best regards, Bruno
icofoam, laminar flow, rotating boundary |
Rotating plate. | farrr | CFX | 7 | July 20, 2015 14:24 |
Rotating thin cylindrical plate heating/cooling | trentar | Main CFD Forum | 0 | August 17, 2012 07:35 |
rotating plate | AlexAlex | FLUENT | 0 | October 11, 2011 12:04 |
vibration of a rotating plate in water | zhm | Main CFD Forum | 0 | March 2, 2010 18:50 |
jet on rotating plate | A.TOUZANI | Main CFD Forum | 0 | January 30, 2003 10:05 |
