January 15, 2013, 22:05 |
Calculation of Epsilon in LES model
Yuri Almeida
Rep Power: 14 |
Dears,
I'm performing flame simulations using the fireFoam solver. The default set for combustion is the eddy dissipation model, which furnishes the equation below for the source term in the species transport eqn: wFuelNorm_ = C_*rho_*turbulence_.epsilon() /max(turbulence_.k(),dimensionedScalar("SMALL",dimV elocity*dimVelocity,SMALL)) *min(YFuel , YO2/s.value()); However, the turbulence model utilized is LES OneEqEddy, which does not directly calculate the epsilon. So, where the epsilon calculation is performed? What expression is used for it? Thanks in advance, Yuri |
January 17, 2013, 11:55 |
Gregor Olenik
Rep Power: 17 |
Hi Yuri,
the oneEqEddy model is derived from the GenEddyVisc model. In GenEddyVisc.H you find that epsilon is computed as Code:
ce_*k()*sqrt(k())/delta(); |
January 18, 2013, 07:43 |
Yuri Almeida
Rep Power: 14 |
Hi Gregor,
Now I got it! Thank you very much! |
LES Filter in Smagorinsky model on inhomogenous grids | Ivan | Main CFD Forum | 1 | October 25, 2012 11:30 |
Implementation of wall model to LES | saeedi | Main CFD Forum | 3 | August 24, 2012 14:51 |
Bug in Dynamic 1Eq Eddy Viscosity LES Model Incompressible flow | harishg | OpenFOAM Bugs | 5 | December 2, 2008 18:18 |
Smagorinsky model | sylvain91 | OpenFOAM Running, Solving & CFD | 0 | June 22, 2006 06:29 |
2-equation model of LES and source code | M.R.Hadian | Main CFD Forum | 0 | February 3, 2002 05:00 |
