adding new liquid
Old   December 30, 2012, 09:07
Default adding new liquid
pushkaraj
pushkaraj is on a distinguished road
hi friends
I am using openfoam-2.1.1 and tried to add new liquid gasoline for my gasoline spray analysis. but while generating the properties with command 'wmake libso' i got following error which says that terminal is not able to open "liquidProperties.H''
details of error are given below:
wmakeLnInclude: linking include files to ./lnInclude
Making dependency list for source file gasoline.C
could not open file liquidProperties.H for source file gasoline.C
could not open file gasolineI.H for source file gasoline.C
SOURCE=gasoline.C ; g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-100 -I/opt/OpenFOAM-2.1.1/src/thermophysicalModels/liquidProperties/lnInclude -I/opt/OpenFOAM-2.1.1/src/thermophysicalModels/thermophysicalFunctions/lnInclude -I/home/pushkaraj/OpenFOAM/pushkaraj-2.1.1/src/thermophysicalModels/thermophysicalFunctions/NSRDSfunctions/lnInclude -IlnInclude -I. -I/opt/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude -I/opt/OpenFOAM-2.1.1/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linuxGccDPOpt/gasoline.o
In file included from gasoline.C:26:0:
gasoline.H:38:30: fatal error: liquidProperties.H: No such file or directory
compilation terminated.
make: *** [Make/linuxGccDPOpt/gasoline.o] Error 1
please help guys.
pushkaraj is offline   Reply With Quote
Old   December 31, 2012, 07:21
Post
T. Chourushi
Tushar@cfd is on a distinguished road
Edit the "make" folder properly... Then the error will be resolved...
Tushar@cfd is offline   Reply With Quote
Old   April 28, 2013, 18:07
NGAYIHI ABBE Claude Valery
Klodval is on a distinguished road
Hi, I am havint the same problem when compiling the new liquid library,
for the problem you have just remove the liquidProperties.C line in the Make/files.
Where I am stuck, is that the compiler is reporting an error stating the liquid class is not defined, what can I do?
Klodval is offline   Reply With Quote
How to define a RGP file for liquid air? eis CFX 2 July 22, 2018 05:51
Help with chtMultiRegionFoam jbvw96 OpenFOAM Running, Solving & CFD 2 December 26, 2010 18:16
RGP file for liquid air eis CFX 0 April 22, 2010 11:34
radiation of molton liquid metal in enclosure richard CFX 0 April 8, 2008 16:43
Need some help for total liquid fraction linus FLUENT 0 December 19, 2006 04:29
