MPI problmes
Old   December 27, 2012, 22:56
Default MPI problmes
Dongyue Li
sharonyue is on a distinguished road
Hi Foamers.
According to this http://www.openfoam.org/download/git.php
After I compiled OF 21x and paraview, there is totally nothing wrong and successfully run solvers.
But I want to run parallel. so I tried, there are some errors:
cfd@cfd:~/OpenFOAM/tutorials/multiphase/interFoam/laminar/damBreak$ mpirun -np 4 interFoam -parallel
[cfd:08509] [[INVALID],INVALID] ORTE_ERROR_LOG: Not found in file runtime/orte_init.c at line 121
Sorry!  You were supposed to get help about:
    orte_init:startup:internal-failure
But I couldn't open the help file:
    /home/cfd/OpenFOAM/ThirdParty-2.1.x/platforms/linux64Gcc/openmpi-1.5.3/share/openmpi/help-orte-runtime: No such file or directory.  Sorry!
[cfd:08509] [[INVALID],INVALID] ORTE_ERROR_LOG: Not found in file orterun.c at line 572
    orterun:usage
    /home/cfd/OpenFOAM/ThirdParty-2.1.x/platforms/linux64Gcc/openmpi-1.5.3/share/openmpi/help-orterun.txt: No such file or directory.  Sorry!
cfd@cfd:~/OpenFOAM/tutorials/multiphase/interFoam/laminar/damBreak$ sudo mpirun
[sudo] password for cfd:
mpirun (Open MPI) 1.5.3
Usage: mpirun [OPTION]...  [PROGRAM]...
Start the given program using Open RTE
   -am <arg0>            Aggregate MCA parameter set file list
   --app <arg0>          Provide an appfile; ignore all other command line
                         options
   -bind-to-board|--bind-to-board
                         Whether to bind processes to specific boards
                         (meaningless on 1 board/node)
   -bind-to-core|--bind-to-core
                         Whether to bind processes to specific cores
   -bind-to-none|--bind-to-none
                         Do not bind processes to cores or sockets
                         (default)
   -bind-to-socket|--bind-to-socket
                         Whether to bind processes to sockets
   -byboard|--byboard    Whether to assign processes round-robin by board
                         (equivalent to bynode if only 1 board/node)
   -bycore|--bycore      Alias for byslot
   -bynode|--bynode      Whether to assign processes round-robin by node
   -byslot|--byslot      Whether to assign processes round-robin by slot
                         (the default)
   -bysocket|--bysocket  Whether to assign processes round-robin by socket
-c|-np|--np <arg0>       Number of processes to run
   -cf|--cartofile <arg0>
                         Provide a cartography file
   -cpu-set|--cpu-set <arg0>
                         Comma-separated list of ranges specifying logical
                         cpus allocated to this job [default: none]
   -cpus-per-proc|--cpus-per-proc <arg0>
                         Number of cpus to use for each process [default=1]
   -cpus-per-rank|--cpus-per-rank <arg0>
                         Synonym for cpus-per-proc
-d|-debug-devel|--debug-devel
                         Enable debugging of OpenRTE
   -debug|--debug        Invoke the user-level debugger indicated by the
                         orte_base_user_debugger MCA parameter
   -debug-daemons|--debug-daemons
                         Enable debugging of any OpenRTE daemons used by
                         this application
   -debug-daemons-file|--debug-daemons-file
                         this application, storing output in files
   -debugger|--debugger <arg0>
                         Sequence of debuggers to search for when "--debug"
                         is used
   -default-hostfile|--default-hostfile <arg0>
                         Provide a default hostfile
   -display-allocation|--display-allocation
                         Display the allocation being used by this job
   -display-devel-allocation|--display-devel-allocation
                         Display a detailed list (mostly intended for
                         developers) of the allocation being used by this
                         job
   -display-devel-map|--display-devel-map
                         Display a detailed process map (mostly intended for
                         developers) just before launch
   -display-map|--display-map
                         Display the process map just before launch
   -do-not-launch|--do-not-launch
                         Perform all necessary operations to prepare to
                         launch the application, but do not actually launch
                         it
   -do-not-resolve|--do-not-resolve
                         Do not attempt to resolve interfaces
   -gmca|--gmca <arg0> <arg1>
                         Pass global MCA parameters that are applicable to
                         all contexts (arg0 is the parameter name; arg1 is
                         the parameter value)
-h|--help                This help message
-H|-host|--host <arg0>   List of hosts to invoke processes on
   --hetero              Indicates that multiple app_contexts are being
                         provided that are a mix of 32/64 bit binaries
   -hostfile|--hostfile <arg0>
                         Provide a hostfile
   -launch-agent|--launch-agent <arg0>
                         Command used to start processes on remote nodes
                         (default: orted)
   -leave-session-attached|--leave-session-attached
   -loadbalance|--loadbalance
                         Balance total number of procs across all allocated
                         nodes
   -machinefile|--machinefile <arg0>
                         Provide a hostfile
   -mca|--mca <arg0> <arg1>
                         Pass context-specific MCA parameters; they are
                         considered global if --gmca is not used and only
                         one context is specified (arg0 is the parameter
                         name; arg1 is the parameter value)
   -n|--n <arg0>         Number of processes to run
   -nolocal|--nolocal    Do not run any MPI applications on the local node
   -nooversubscribe|--nooversubscribe
                         Nodes are not to be oversubscribed, even if the
                         system supports such operation
   --noprefix            Disable automatic --prefix behavior
   -nperboard|--nperboard <arg0>
                         Launch n processes per board on all allocated
                         nodes
   -npernode|--npernode <arg0>
                         Launch n processes per node on all allocated nodes
   -npersocket|--npersocket <arg0>
                         Launch n processes per socket on all allocated
                         nodes
   -num-boards|--num-boards <arg0>
                         Number of processor boards/node (1-256) [default:
                         1]
   -num-cores|--num-cores <arg0>
                         Number of cores/socket (1-256) [default: 1]
   -num-sockets|--num-sockets <arg0>
                         Number of sockets/board (1-256) [default: 1]
   -ompi-server|--ompi-server <arg0>
                         Specify the URI of the Open MPI server, or the name
                         of the file (specified as file:filename) that
                         contains that info
   -output-filename|--output-filename <arg0>
                         Redirect output from application processes into
                         filename.rank
   -path|--path <arg0>   PATH to be used to look for executables to start
                         processes
   -pernode|--pernode    Launch one process per available node on the
                         specified number of nodes [no -np => use all
                         allocated nodes]
   --prefix <arg0>       Prefix where Open MPI is installed on remote nodes
   --preload-files <arg0>
                         Preload the comma separated list of files to the
                         remote machines current working directory before
                         starting the remote process.
   --preload-files-dest-dir <arg0>
                         The destination directory to use in conjunction
                         with --preload-files. By default the absolute and
                         relative paths provided by --preload-files are
                         used.
-q|--quiet               Suppress helpful messages
   -report-bindings|--report-bindings
                         Whether to report process bindings to stderr
   -report-events|--report-events <arg0>
                         Report events to a tool listening at the specified
                         URI
   -report-pid|--report-pid <arg0>
                         Printout pid on stdout [-], stderr [+], or a file
                         [anything else]
   -report-uri|--report-uri <arg0>
                         Printout URI on stdout [-], stderr [+], or a file
                         [anything else]
   -rf|--rankfile <arg0>
                         Provide a rankfile file
-s|--preload-binary      Preload the binary on the remote machine before
   -server-wait-time|--server-wait-time <arg0>
                         Time in seconds to wait for ompi-server (default:
                         10 sec)
   -show-progress|--show-progress
                         Output a brief periodic report on launch progress
   -slot-list|--slot-list <arg0>
                         List of processor IDs to bind MPI processes to
                         (e.g., used in conjunction with rank files)
   -stdin|--stdin <arg0>
                         Specify procs to receive stdin [rank, all, none]
                         (default: 0, indicating rank 0)
   -stride|--stride <arg0>
                         When binding multiple cores to a rank, the step
                         size to use between cores [default: 1]
   -tag-output|--tag-output
                         Tag all output with [job,rank]
   -timestamp-output|--timestamp-output
                         Timestamp all application process output
   -tmpdir|--tmpdir <arg0>
                         Set the root for the session directory tree for
                         orterun ONLY
   -tv|--tv              Deprecated backwards compatibility flag; synonym
                         for "--debug"
   -use-regexp|--use-regexp
                         Use regular expressions for launch
-v|--verbose             Be verbose
-V|--version             Print version and exit
   -wait-for-server|--wait-for-server
                         If ompi-server is not already running, wait until
                         it is detected (default: false)
   -wd|--wd <arg0>       Synonym for --wdir
   -wdir|--wdir <arg0>   Set the working directory of the started processes
-x <arg0>                Export an environment variable, optionally
                         specifying a value (e.g., "-x foo" exports the
                         environment variable foo and takes its value from
                         the current environment; "-x foo=bar" exports the
                         environment variable name foo and sets its value to
                         "bar" in the started processes)
   -xml|--xml            Provide all output in XML format
   -xml-file|--xml-file <arg0>
                         Provide all output in XML format to the specified
                         file
   -xterm|--xterm <arg0>
                         Create a new xterm window and display output from
                         the specified ranks there
Report bugs to http://www.open-mpi.org/community/help/
cfd@cfd:~/OpenFOAM/tutorials/multiphase/interFoam/laminar/damBreak$ sudo su
root@cfd:/home/cfd/OpenFOAM/tutorials/multiphase/interFoam/laminar/damBreak# mpirun -np 4 interFoam -parallel
mpirun was unable to launch the specified application as it could not find an executable:
Executable: interFoam
Node: cfd
while attempting to start process rank 0.
4 total processes failed to start
How to fix this? Thanks in advance
sharonyue is offline   Reply With Quote
Old   December 28, 2012, 00:31
Post Dear sharonyue,
T. Chourushi
Tushar@cfd is on a distinguished road
Have you done? "decomposePar" properly?..
I think you should check your file "decomposeParDict"...
All the best...
Tushar@cfd is offline   Reply With Quote
Old   December 28, 2012, 01:36
Dongyue Li
All the best...
~Yes,I have done that~
Old   December 28, 2012, 02:42
T. Chourushi
Can you please copy-paste the "decomposeParDict" code here... So that I will have a better idea...
Old   December 28, 2012, 04:40
Dongyue Li
numberOfSubdomains 4;
method          simple;
simpleCoeffs
    n               ( 2 2 1 );
    delta           0.001;
hierarchicalCoeffs
    n               ( 1 1 1 );
    delta           0.001;
    order           xyz;
manualCoeffs
    dataFile        "";
distributed     no;
roots           ( );
I think its tough to install openmpi for myself.
Old   December 28, 2012, 04:56
Dongyue Li
I do strictly according to this page. http://www.openfoam.org/download/git.php
But I can NOT install openmpi correctly. Its driving me crazy and upset!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old   December 28, 2012, 05:14
Post
T. Chourushi
1) Install "openmpi-bin" and after that
2) Try running this command...
Old   December 28, 2012, 05:16
Dongyue Li
yeah, I have installed that...
Old   December 28, 2012, 05:17
Laurence R. McGlashan
l_r_mcglashan will become famous soon enough
What is the result of:
ls $WM_THIRD_PARTY_DIR/platforms/linux64Gcc/openmpi-1.5.3/share/openmpi/
Does that path exist?
And also post the output of the Allwmake script that you ran in $WM_THIRD_PARTY_DIR.
cd $WM_THIRD_PARTY_DIR
./Allwmake > log.make 2>&1 &
Nobody can help you unless you provide more information.
P.S. Do not run stuff as root.
Laurence R. McGlashan :: Website
l_r_mcglashan is offline   Reply With Quote
Old   December 28, 2012, 05:28
Dongyue Li
no it does not exits.
cfd@cfd:~/OpenFOAM/ThirdParty-2.1.x/platforms/linux64Gcc$ ls
paraview-3.12.0
I installed openmpi153 this way:
cd OpenFOAM/ThirdParty-2.1.x/openmpi1.5.3
./configure
make all install
then I set the .bashrc but it does not work. actually I dont know how to set the .bashrc. I search the internet.............
forget it !!!!! I just re-install my ubuntu and compile Openfoam.. I am totally pissed off! I am running interFoam on a mesh with 3,000,000 cells. thats too slow! I cant endure that. now I am so upset. I got have a rest.
anyway Thank you guys very much. I will update my problem later after I reinstall my ubuntu and foam.
Old   December 28, 2012, 05:38
Originally Posted by sharonyue View Post
forget it !!!!! I just re-install my ubuntu and compile Openfoam.. I am totally pissed off!.
Don't do that, it will take even longer!
Unpack the openmpi sources into $WM_THIRD_PARTY_DIR and then just run the Allwmake script in $WM_THIRD_PARTY_DIR. That will install openmpi for you.
Old   December 28, 2012, 05:40
Post
  #12
T. Chourushi
Check this link...
http://auriza.site40.net/notes/mpi/o...on-ubuntu-904/
Try installing it from the command prompt..
Best of luck...
mpirun, best parameters pablodecastillo Hardware 18 November 10, 2016 13:36
MPI error florencenawei OpenFOAM Installation 3 October 10, 2011 02:21
Error using LaunderGibsonRSTM on SGI ALTIX 4700 jaswi OpenFOAM 2 April 29, 2008 11:54
Is Testsuite on the way or not lakeat OpenFOAM Installation 6 April 28, 2008 12:12
MPI and parallel computation Wang Main CFD Forum 7 April 15, 2004 12:25
