properties of solid mixture
Old   December 26, 2012, 14:59
Default properties of solid mixture
Ahmed Khattab's Avatar
ahmed
Ahmed Khattab is on a distinguished road
Hi every one,
i use chtMultiRegionFoam solver which contains in its 0 folder these parameters Ypmma, and Ychar, which i suppose after searching to be component of mixture for solid region.
in the tutorial case this solid model is used:
thermoType constSolidThermo;
in log file chtMultiRegionFoam.log properties are listed for solid region like this:
*** Reading solid mesh thermophysical properties for region innerTube
    Adding to thermos
Constructed constSolidThermo with
    rho        : rho [1 -3 0 0 0 0 0] 8000
    Cp         : Cp [0 2 -2 -1 0 0 0] 450
    K          : K [1 1 -3 -1 0 0 0] 80
    Hf         : Hf [0 2 -2 0 0 0 0] 0
    emissivity : emissivity [0 0 0 0 0 0 0] 0
    kappa      : kappa [0 -1 0 0 0 0 0] 0
    sigmaS     : sigmaS [0 -1 0 0 0 0 0] 0
in order to test solid mixture i changed the solid model by this one:
thermoType solidMixtureThermo<multiComponentSolidMixture<cons tSolidTransport<constSolidRad<constSolidThermo<con stRho>>>>>;
and changed some values of Ypmma, and Ychar. when looking in log file to see calculated properties i didn't found values instead i found this:
    Adding to thermos
can any one tell me how to find values of the properties to insure how solver calculated solid mixture properties ?
thanks in advance
Ahmed Khattab is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Solid Properties Setup In Simulation of Porous Media Modest Cat FLUENT 4 March 26, 2012 06:00
error message cuteapathy CFX 14 March 20, 2012 07:45
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
