How to create a case with a karman vortex using openfoam? |
January 5, 2017, 18:20 |
#21 | |
Joern Beilke
Rep Power: 20 |
Putting it on GitHub without asking and without a link to the original place is not very nice. Jörn |
September 19, 2021, 12:37 |
Fatal Error running karman case
#22 | |
qutadah
Rep Power: 5 |
i downloaded the case and ran pimpleFoam but Fatal Error.. "Starting time loop Courant Number mean: 0.16928 max: 2.70568 Time = 0.001 --> FOAM FATAL IO ERROR: wrong token type - expected word, found on line 32 the label 1 file: /storage/rababqjt/tutorials/Karmann_OpenFoam/karmann_gridpro_pimple/system/fvSchemes.divSchemes.div((nuEff*dev2(T(grad(U))))) at line 32. From function Foam::Istream& Foam:perator>>(Foam::Istream&, Foam::word&) in file primitives/strings/word/wordIO.C at line 74. FOAM exiting " do you have any idea how i can solve this error? |
September 19, 2021, 16:30 |
#23 |
Joern Beilke
Rep Power: 20 |
I've made some changes and tested it with v1912. So it should work now. Have fun.
September 20, 2021, 03:52 |
#24 |
qutadah
Rep Power: 5 |
its still having a problem, i am running the Openfoam 6 version...
What are exactly the steps to run the simulation? I figure since mesh is already there, we need only to: 1. decomposePar 2. pimpleFoam 3. reconstructPar 4. paraview are these the correct steps? where is the problem? thanks! Last edited by qutadah.r; September 20, 2021 at 05:01. Reason: wrong analysis |
September 20, 2021, 09:06 |
#25 |
Joern Beilke
Rep Power: 20 |
September 30, 2021, 20:15 |
#26 |
Edgar Alejandro Martínez Ojeda
Rep Power: 7 |
I made a tutorial, you can find the files in my repository: https://www.youtube.com/watch?v=A1YQ9eZQFcg
October 2, 2021, 14:13 |
#27 | |
qutadah
Rep Power: 5 |
thanks, i was struggling with the Allrunscript and how it works, glad to know how it works now |
How to Create .msh file so that when converted to OpenFOAM will have some BC | jaypatel | OpenFOAM | 13 | November 9, 2017 08:44 |
[GAMBIT] How to plot S pipe | mariam.sara | ANSYS Meshing & Geometry | 36 | November 7, 2013 16:22 |
karman vortex street help please | SSeth | STAR-CCM+ | 7 | January 10, 2011 12:31 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 13:24 |
Kármán vortex street in cavitating flow behind bodies in the cavitation tunnel | L. Könözsy | Main CFD Forum | 0 | April 17, 2000 14:16 |
