convergence in PISO loop of icoFoam
Old   December 3, 2012, 22:37
Default convergence in PISO loop of icoFoam
hawkeye321 is an unknown quantity at this point
Hi FOAMERS
I am simulating a laminar double diffusive natural convection with phase change in OF. The solver is mainly based on icoFoam. AFter postprocessing the results, I see that in the two phase (solid/liquid) region I have flow into the wall, which indicates that my solution is not fully converged. The tolerance for linear solvers are 1e-5, and for the PISO loop parameters in the fvsolution I have set
PISO
nCorrectors 2;
nNonOrthogonalCorrectors 0;
convergenceCriterion 1.0e-5;
pRefCell 0;
pRefValue 0;
residualControl
p 1e-5;
U 1e-5;
// Add other variables here
Since I have flow into the wall, my residuals should be higher than the 1e-5 in the residualControl; and, as far as I can tell, I get no warning about this from the OF. So can anyone help me to figure out
(1): why why does the OF gives me a solution which does not satisfy the residuals I have set?
(2): Does specifying or not specifying the residualControl in the fvsolution has any effect on the simulation?
hawkeye321 is offline   Reply With Quote
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
about the pEqn in PISO loop of icoFoam young_Cao OpenFOAM Running, Solving & CFD 4 June 1, 2012 23:36
Force can not converge colopolo CFX 13 October 4, 2011 23:03
[CAD formats] my stl surface is seen as just a line rcastilla OpenFOAM Meshing & Mesh Conversion 2 January 6, 2010 02:30
NACA0012 geometry/design software needed Franny Main CFD Forum 13 July 7, 2007 16:57
