what means?word::stripInvalid() called for word r For debug level (= 2) > 1 |
December 3, 2012, 18:17 |
Ehsan
Rep Power: 27 |
Mean and max Courant Numbers = 0.0995124 0.209916
deltaT = 4.7619e-08 Time = 4.7619e-08 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUx, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUy, Initial residual = 0, Final residual = 0, No Iterations 0 swak4Foam: Allocating new repository for sampledGlobalVariables smoothSolver: Solving for Ux, Initial residual = 2.37033e-06, Final residual = 2.45847e-17, No Iterations 3 smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 1.45241e-16, No Iterations 3 diagonal: Solving for rhoE, Initial residual = 0, Final residual = 0, No Iterations 0 smoothSolver: Solving for e, Initial residual = 2.05419e-06, Final residual = 4.50787e-11, No Iterations 3 word::stripInvalid() called for word r For debug level (= 2) > 1 this is considered fatal Aborted |
December 4, 2012, 12:18 |
RZA
Rep Power: 14 |
Hi Ehsun
What is your problem type, model setup and solver? I think u should check ur model setup thoroughly if this error is coming before starting of iterations. If its appearing after some iterations then u can play with the relaxation parameters or check the quality of ur grid. Good Luck |
reconstructPar --> fileName::stripInvalid() called for invalid fileName commandtouse | adona058 | OpenFOAM Bugs | 34 | December 8, 2022 22:27 |
under-relaxation factors -> level of residuals | Zigainer | FLUENT | 19 | July 21, 2017 17:53 |
[snappyHexMesh] Adding layers goes wrong with SnappyHexMesh | Elise | OpenFOAM Meshing & Mesh Conversion | 1 | April 22, 2013 03:32 |
[snappyHexMesh] Boundary layer in a pipe | Clementhuon | OpenFOAM Meshing & Mesh Conversion | 6 | March 12, 2012 13:41 |
reconstructParMesh not working with an axisymetric case | francesco | OpenFOAM Bugs | 4 | May 8, 2009 06:49 |
