rhoeqn is not calculating in rhoCentralFoam
Old   December 2, 2012, 07:35
Default rhoeqn is not calculating in rhoCentralFoam
Farshad
Farshad_Noravesh is on a distinguished road
I have a problem to run a NACA0012 at mach=0.8 using rhoCentralFoam.
I have attached my case. The problem is that the rho and rhoUx and rhoUy are not changing and the residual is always zero.
Thanks for help
Farshad
Farshad_Noravesh is offline   Reply With Quote
Old   December 3, 2012, 04:45
Nima Samkhaniani
nimasam is on a distinguished road
check your upload test case it seems you upload wrong test case
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   December 15, 2020, 05:53
Default Same problem
Onur Koç
Onur Koç is on a distinguished road
Originally Posted by Farshad_Noravesh View Post
Thanks for help
Farshad
hi,I am also same problem.Did you find the solution ?
Onur Koç is offline   Reply With Quote
rhoCentralFoam solver with Slip BCs fails in Parallel Only JLight OpenFOAM Running, Solving & CFD 2 October 11, 2012 22:08
Calculating forces on a non-closed surface ScottN FLUENT 0 March 1, 2011 18:18
Problems in calculating the fluid traction on the current structure frame in 3D models fw407 OpenFOAM Running, Solving & CFD 0 August 6, 2008 13:04
Calculating time thuy FLUENT 5 April 10, 2008 05:23
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 18:27
