Gmsh+SimpleFoam issue
Old   November 20, 2012, 12:17
Default Gmsh+SimpleFoam issue
Hernán
vhgarzonr is on a distinguished road
Hi, I'm sorry for my bad English.
I'm new in this forum and with OpenFoam, and I'm trying to run with simpleFoam the flux of water in an elbow. For that I've made the mesh with Gmsh and exported to Foam with gmshToFoam command.
Checking several discussions in this blog I formulated the different support archives, but when I try to run it, I just got few time's evaluations and I notice that the values of U, p, k, epsilon increases rapidly without a convergence.
I tried changing the mesh dimensions, changing time interval, and other different options but the result is the same: DIVERGENCY!!!
I appreciate if any of you can help me giving me a light with the reason of this problem, cause I'm a kind of desperate with this issue because I need this for my graduation.
This is the error message that I got on the 6th iteration:
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#2 Uninterpreted:
#3 Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#4 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libfiniteVolume.so"
#5 Foam::fvMatrix<double>::solve() in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libincompressibleRASModels.so"
#6 Foam::incompressible::RASModels::kEpsilon::correct () in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libincompressibleRASModels.so"
in "/opt/openfoam211/platforms/linuxGccDPOpt/bin/simpleFoam"
#8 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6"
Excepción de coma flotante (`core' generado)
vhgarzonr is offline   Reply With Quote
elbow flow, gmsh, simplefoam convergence, simplefoam stability
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
simpleFoam serious mass balance issue fivos OpenFOAM Running, Solving & CFD 2 November 6, 2011 09:21
[Gmsh] gmsh SIMPLEFoam error pcaste12 OpenFOAM Meshing & Mesh Conversion 8 June 26, 2011 12:45
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 11:56
Issue with SimpleFoam with Sharp corners kdneroorkar OpenFOAM Running, Solving & CFD 13 September 15, 2008 19:12
