October 29, 2012, 19:41 |
Simple 2D Parallel Heat Conduction
Rep Power: 14 |
I am running a simple 2D heat condition problem in parallel. The domain is decomposed into 4 equal regions in the horizontal direction. The temperature contour looks like file 4 in attachment. However, While when I am running the case on 1 processor the contour looks like file 1. As you see, the temperatures do not seem to be right at the intersection of the domains, solved by different processors. Any idea what is wrong?
Heat transfer (conduction) between two pipes | shields | FLUENT | 14 | February 3, 2016 08:45 |
flow thru parallel plate with solid heat generater | cindy | FLUENT | 1 | October 10, 2005 23:54 |
Conduction heat not balanced? | Nepal | CFX | 7 | May 31, 2005 12:51 |
Heat conduction through solid rib in periodic duct | Dieter Fauconnier | FLUENT | 0 | October 7, 2004 09:22 |
heat conduction in a solid | francesco | FLUENT | 0 | May 27, 2004 19:00 |
