Cyclic boundaries in OF 21x
Like Tree10Likes
Old   May 3, 2013, 19:09
pooyan
sam1364 is on a distinguished road
Dear maddalena and Michaelthanks to your comments on this page, I was able to create cyclic patches in openfoam 2.1.0 for 2D geometry. But, when I used the same instruction for 3D geometry, it failed. what could be the possible reason?
So, in my geometry, I want the inlet,outlet, front and back planes to be cyclic
Just I want to emphasize that, to define two patches as cyclic, I did not have any problem. but for four patches to be cyclic, I had issues. I did creating cyclic patches for each pair separately which did not work either.
I have attached the createPatchDict and my boundary
I would be grateful if you can help me.
Thanks
boundary:
front
type patch;
nFaces 8288;
startFace 2780326;
back
type patch;
nFaces 8288;
startFace 2788614;
inflow
type patch;
nFaces 8362;
startFace 2796902;
outflow
type patch;
nFaces 8362;
startFace 2805264;
wall1
type wall;
nFaces 12656;
startFace 2813626;
wall2
type wall;
nFaces 12656;
startFace 2826282;
createPatch:
pointSync true;
// Patches to create.
patches
// Name of new patch
name inflow_cyclic;
// Type of new patch
patchInfo
type cyclic;
matchTolerance 0.001;
neighbourPatch outflow_cyclic;
// How to construct: either from 'patches' or 'set'
constructFrom patches;
// If constructFrom = patches : names of patches. Wildcards allowed.
patches ( inflow );
name outflow_cyclic;
patchInfo
type cyclic;
neighbourPatch inflow_cyclic;
patches ( outflow );
name front_cyclic;
patchInfo
type cyclic;
neighbourPatch back_cyclic;
patches ( front );
name back_cyclic;
patchInfo
type cyclic;
neighbourPatch front_cyclic;
patches ( back );
sam1364 is offline   Reply With Quote
Old   May 6, 2013, 03:25
maddalena's Avatar
maddalena
maddalena will become famous soon enough
Hi Sam,
your problem may lay here:
Originally Posted by sam1364 View Post
createPatch:
pointSync true;
as explained in createPatchDict example you have on your OpenFoam installation:
// Do a synchronisation of coupled points after creation of any patches.
// Note: this does not work with points that are on multiple coupled patches
//       with transformations (i.e. cyclics).
pointSync false;
Thus if you have front patch sharing some points with inflow or outflow patch, then your createPatch will not work.
Hope this help.
mad
NB: double posting is NEVER a good idea!
michael1023 and sam1364 like this.
maddalena is offline   Reply With Quote
Old   May 8, 2013, 19:06
pooyan
thanks. I guess the problem is solved based on your comment.
michael1023 likes this.
Old   May 10, 2013, 05:50
James Davies
james80 is on a distinguished road
I am running a case alongside one on fluent, hoping to compare the two. I have imported the mesh from gambit and appear to have succesfully implemented createPatchDict to create the cyclic boundarys.
The case starts to run, but when it goes to seed the first set of results, i get the following error:
More than one patch accesing the same transform but not of the same sign.
patch: cyc_half0 transform:0 sign:1 current transforms: (1 0 0)
Anyone have any ideas about how to solve this issue?
any help greatly appreciated
James
james80 is offline   Reply With Quote
Old   May 13, 2013, 22:34
pooyan
which version of OF did you use? if you are using 2.1.X, you should be able to create the cyclic boundaries following this page instruction.
QUOTE=james80;426484]Hi,
James[/QUOTE]
Old   May 13, 2013, 23:35
pooyan
Dear Mad and Michael,
I was successful in creating cyclic patches for my geometry. Now, my question is regarding the parallel processing. is it enough to add "preservepatches (cyclic boundaries);" into decomposeParDict and then run decomposePar at the terminal? or I should do something extra in order to decompose a domain with cyclic patches?
Thanks,
pooyan
Problem with cyclic boundaries in Openfoam 1.5 fs82 OpenFOAM 37 November 29, 2024 11:15
Parallel refineMesh with Cyclic Boundaries mchurchf OpenFOAM 8 December 22, 2018 12:11
mapFields - Changing from turbulentInlet/outlet boundaries to cyclic boundaries TianC OpenFOAM Pre-Processing 8 January 16, 2013 06:15
Wrong wall distance with cyclic boundaries sebastian OpenFOAM Bugs 4 October 31, 2012 11:24
Problems with cyclic boundaries in faMeshDefinition and surfactantFoam safre OpenFOAM 3 December 12, 2011 08:56
