elemenst of surface scalerfield
Old   October 21, 2012, 17:23
Default elemenst of surface scalerfield
hawkeye321 is an unknown quantity at this point
HI FOAMERS
I have a surface scaler field named glS which is equal to
surfaceScalarField gLS = fvc::interpolate(gL);
wher gL in volscalerfield.
The loop for all (celli,gl) can check all the element of gL, is there a similar command to check the elements of surfacesclar field, gLS?
TNX for your help!
hawkeye321 is offline   Reply With Quote
Old   October 22, 2012, 04:06
Kathrin Kissling
kathrin_kissling is on a distinguished road
Hey,
it works absolutely the same:
forAll(mySurfaceScalarField, faceI)
forAll(list, i) is just a function wrapping for (Foam::label i=0; i<(list).size(); i++)
its defined in UList.H
it works for all containers having a .size() function!
Best
Kathrin
kathrin_kissling is offline   Reply With Quote
Old   October 24, 2012, 10:30
Default Thanks
kathrin, thanks for the comment!
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 12:05
import solids Alessio85 STAR-CCM+ 5 November 11, 2011 14:16
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 13:43
Patran Volume Meshing Deb CFX 19 April 17, 2003 11:56
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin Kaushik FLUENT 1 May 8, 2000 07:47
