Problem in parallel run on 2 machine
Old   October 19, 2012, 07:07
Exclamation Problem in parallel run on 2 machine
Tushar
Tush is on a distinguished road
Dear Foamers,
How to connect the 2 machines, and run the code by utilizing both of their processors?
I am getting the following error while executing the decomposeParDict file.
--> FOAM FATAL ERROR:
Case is already decomposed with 4 domains, use the -force option or manually
remove processor directories before decomposing. e.g.,
rm -rf /home/tush/OpenFOAM/OpenFOAM-2.1.1/foam_run/parallel_test_runs/parallel_cavity/processor*
From function decomposePar
in file decomposePar.C at line 241.
FOAM exiting
Note: that I have deleted the processor directory, but still the error continues.
Earlier I have specified the path of two machines in the "decomp...." file. by using:
distributed yes;
roots 1
"10.10.30.123@ home/machine2/OpenFOAM/OpenFOAM-2.1.1/tutorials/tests/cavity_tests"
Thanks in advance...
Tush is offline   Reply With Quote
Old   October 19, 2012, 07:24
Tushar
Sorry, to bother You. I have solved my problem by using earlier threads of FOAM.
Script to Run Parallel Jobs in Rocks Cluster asaha OpenFOAM Running, Solving & CFD 12 July 4, 2012 23:51
SnappyHexMesh OF-1.6-ext crashes on a parallel run norman1981 OpenFOAM Bugs 5 December 7, 2011 13:48
Working directory via command line Luiz CFX 4 March 6, 2011 21:02
Problem running a parallel fluent job on local machine via mpd highhopes FLUENT 0 March 3, 2011 06:07
Passing calculated values in parallel run wese OpenFOAM Running, Solving & CFD 6 April 3, 2008 11:04
