Beginner level doubts with turbulent flow simulation setup
Old   October 17, 2012, 09:26
Default Beginner level doubts with turbulent flow simulation setup
Sagun Tripathi
Sagun is on a distinguished road
Hello everyone,
I am attempting to simulate multiphase turbulent flow for the first time in OpenFOAM. The two fluids present in my domain are air and water (at standard conditions) with velocity of each at inlet being 5 m/s. The domain is essentially a 2-D box of dimensions 20mx0.1mx5m (empty along 'y') with water upto a height of 2m. I have the following questions in mind as I try to simulate this situation:
1. Well, this may sound really stupid but I was thinking that since there are two fluids in the domain and flow is turbulent in each, for which fluid should parameters like k, epsilon and nu_t be calculated and assigned to the patches in the 0 folder?
2. Coming to the question of calculating these parameters, could you please tell me how to go about it? I think I calculate k and epsilon using the damBreak tutorial as a reference and nu_t using the formula give on this page: http://www.cfd-online.com/Wiki/Standard_k-epsilon_model
But I'm not sure if my approach is correct. Any comments? Also, I observed that for wall patches, epsilonWallFunction and kqRWallFunction are used for epsilon and k respectively with a uniform value of 0.1. How does one arrive at this value of 0.1?
3. Also, what should be the boundary condition at the inlet for a property like k or epsilon or nu_t? Because I'm defining each one of them only for one fluid and there are two fluids present in the domain at the inlet.
Sorry for barging you all with so many questions. I could really use some help here.
Thanks,
Sagun
Sagun is offline   Reply With Quote
Old   October 22, 2012, 10:56
Sagun Tripathi
No advice? Am I being too vague too?
Problem with divergence TDK FLUENT 13 December 14, 2018 07:00
[snappyHexMesh] Adding layers goes wrong with SnappyHexMesh Elise OpenFOAM Meshing & Mesh Conversion 1 April 22, 2013 03:32
Turbulent Flow in Straight Square Duct - k-ep Validation mcclud STAR-CCM+ 2 August 7, 2012 17:56
Doubts on how to represent some terms for viscoelastic Flow Simulation titio OpenFOAM Running, Solving & CFD 0 February 4, 2009 08:42
Natural convection - Inlet boundary condition max91 CFX 1 July 29, 2008 21:28
