Immersed mesh - STL mesh intersection
Old   October 17, 2012, 06:55
Lightbulb Immersed mesh - STL mesh intersection
Arvind Bharathi
arvind3008 is on a distinguished road
Hi all,
I will be working on a project of which I have given a brief description:
The work is to enable visualization of data for immersed boundaries in Tecplot. Essentially, there is a refined hex mesh with a STL surface mesh (triangular elements to describe the surface geometry). The hex mesh cells lie both inside and outside of the geometry. Hence, some cells are cut by the STL mesh. The objective is to detect these cells, then detect the points of intersection and convert these hex cells into polyhedral cells so that they can be visualized in Tecplot.
I thought of using the snappyHexMesh tool from open-foam, but I realized that it morphs the cells around the geometry rather than computing intersection points.
So what I want to know is if you know any tool in OpenFoam (or otherwise) that can do this?
Thank you
Arvind
arvind3008 is offline   Reply With Quote
Old   October 17, 2012, 14:24
nsf
Nicolas Edh
nsf is on a distinguished road
If your in to programing and I would recommend VTK. One could say its whats paraview is based on. You could say that vtk is all the math in paraview (and probably more). There are some pre built classes that handle interpolation.
Have a look at this example
http://www.vtk.org/Wiki/VTK/Examples...onIntersection
Best and good luck
/Nicolas
nsf is offline   Reply With Quote
Old   October 18, 2012, 10:17
Arvind Bharathi
@Nicolas...Thank you for the reply. I went through the example. It seems that the example describes finding the intersection of a line with a surface. I am more looking for intersection of a volume (the mesh cell) with a surface (STL). Do you perhaps know any eample of this?
Thank you
Old   October 18, 2012, 15:56
nsf
Nicolas Edh
I have little experience my self. I've only used vtk on a hobby basis.
However it did find this with a little bit of google:
http://www.vtk.org/pipermail/vtkuser...il/116435.html
They reefer to this site that looks promising
http://www.vtkjournal.org/browse/publication/726
/Nicolas
immersed mesh, stl-mesh, tecplot
[ICEM] generate mesh from stl file for mechanical APDL rupan ANSYS Meshing & Geometry 1 May 5, 2019 22:54
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 10:03
[ICEM] Problem making structural mesh on a surface froztbear ANSYS Meshing & Geometry 1 November 10, 2011 09:52
[Netgen] Netgen mesh settings for STL geometries lucchini OpenFOAM Meshing & Mesh Conversion 3 March 7, 2011 02:02
