How to compute surface area of rising bubble
Like Tree8Likes
Old   June 27, 2015, 16:29
HM
hojjat.m is on a distinguished road
BTW is there anyway I can convert the surfaceVectorField into volVectorField?
Thanks
hojjat.m is offline   Reply With Quote
Old   May 24, 2016, 15:57
Arsalan
arsalan.dryi is on a distinguished road
Hi Foamers,
I'm doing a 3D simulation of two and three bubble rising using a modified interFoam solver and I need to bubbles centre position, velocity and surface area.
For a single bubble rising I used swak4Foam expressions for example for bubble centre position in Y as follows :
    bubbleCentreY
        type swakExpression;
        valueType internalField;
        verbose true;
    variables (
    "Vol= sum (alpha1 < 0.5 ? vol() : 0);"
    "VolY= sum (alpha1 < 0.5 ? pos().y*vol() : 0);"
    expression "VolY/Vol";
        accumulations (
        min
Is there a way to compute two or three bubble properties in this manner?
Thanks in advance,
Best Regards,
Arsalan.
arsalan.dryi is offline   Reply With Quote
Old   November 17, 2019, 14:50
FaRa
Fahmida is on a distinguished road
Originally Posted by gschaider View Post
Right. That was there to "normalize out" the thickness of the 2D-mesh
About the discrepancy in size: no idea. Of course the isoSurface is naive about what you want to achive. So if in your simulation you have a bubble and a water surface then an iso-value of 0.5 will pick up the bubble AND the surface (that would explain the order-of-magnitude error). A bit creative playing around with the expressionField-functionObject might help here
Could you please explain a little more on how to separate the air above the water surface and bubble air while calculating?
Fahmida is offline   Reply With Quote
Old   May 25, 2021, 05:57
Bushra Rasheed
B_R_Khan is on a distinguished road
Hello foamers!
I want to calculate surface area of rising bubble without using swake4foam. In paraview, I am using integrate variables to integrate alpha.water over whole domain but I need to incorporate the calculation of surface area in control dict. Is there any function object to do this? Please help me out.
Thanks
B_R_Khan is offline   Reply With Quote
Rising bubble with interFoam tayo OpenFOAM Running, Solving & CFD 16 March 12, 2020 13:11
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
[snappyHexMesh] Layers don't fully surround surface EVBUCF OpenFOAM Meshing & Mesh Conversion 14 August 20, 2012 05:31
Cross section and surface area factor Fabiana CFX 0 January 10, 2006 00:51
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
