How to compute surface area of rising bubble
Like Tree8Likes
Old   January 10, 2014, 09:52
Nazanin
Nazanin is on a distinguished road
Originally Posted by Andrea_85 View Post
Hi all,
i guess that the total interfacial area can be simply calculated using:
\Sum_i=1:N \grad\alpha_i * \deltaV_i
where N is total numer of cells in your domain. This gives you an area in m^2, so if your case is 2-D and you just need the lenght of the interfacial line you have to normalized by the thickness.
This is consistent with the CSF method implemented in interFoam.
Best
andrea
Thank you very much for reply andrea..
Do you know how I can determine changing bubble diameter during run and relative velocity??
Best
Nazanin is offline   Reply With Quote
Old   January 10, 2014, 10:06
Andrea Ferrari
Andrea_85 is on a distinguished road
supposing that your bubble remains a sphere (or circle in 2-D) and does not deform then if you have the surface area you can calculate the radius(diameter) using area formulas
2-D -> 2*Pi*R = surfaceArea/thickness
3-D -> 4*Pi*R^2 = surfaceArea
and what do you mean with "relative velocity"? Is it the mean rising velocity?
If yes, you can for example calculate the mean velocity of the center of mass which gives you the mean velocity of the rising bubble.
best
andrea
Andrea_85 is offline   Reply With Quote
Old   January 10, 2014, 10:17
Nazanin
best
andrea
Thank you very much.
If I want use your idea,should I writing code for my solver or I can use swak4foam?
relative velocity means:
that Ux Uy Uz is bubble velocty and Ul is local liquid velocity...
Old   January 10, 2014, 10:36
Andrea Ferrari
It depends what you want to do with diameter and velocity. Do you need them during the simulation, because for example they appear in some new equations you are solving or you just need them in the post-processing?
Old   January 10, 2014, 10:44
Nazanin
I want plot these parameters after simulation (post-prosessing) ..
I found in swak4Foam examples (capilaryRise-test case) that use simpleSwakFunctionObjects and swakFunctionObjects for compute some parameters like this but I dont know how determine for my case study??
Old   January 12, 2014, 06:12
Andrea Ferrari
i think the best would be write your own script that does all the calculations. Have a look in application/utilities/postprocessing.
There you have a lot of examples. You can modify the main part of one of those to read the correct quantities and print what you need.
best
andrea
Old   January 22, 2014, 20:14
Assistant Moderator
Bernhard Gschaider
I'm still unsure what the actual problem is:
- you have already done the simulation and want to do the calculation on the data on disc: funkyDoCalc might help you there (it can do all the things swakExpression can do)
- or you want to use swakExpression and are unclear about the actual expressions to use?
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   March 13, 2015, 15:59
Raunak Bardia
raunakbardia is on a distinguished road
Thanks a lot.
I needed an approximate and I was trying to implement a lot of different techniques to get the surface area but swak did the trick easily.
raunakbardia is offline   Reply With Quote
Old   June 23, 2015, 15:54
Default Normal vector at the interface
  #29
HM
hojjat.m is on a distinguished road
Hello Foamers;
I am using interFoam, and I was wondering if there is anyway that we can access to the normal vector at the interface. I mean I want to have the normal vector in my results. Any feedback is appreciated
hojjat.m is offline   Reply With Quote
Old   June 23, 2015, 19:05
Andrea Ferrari
The interface unit normal vector is defined as:
n = grad(alpha)/mag(grad(alpha))
In interfaceProperties.C it is calculated at the face centres at line 125
surfaceVectorField nHatfv(gradAlphaf/(mag(gradAlphaf) + deltaN_));
(deltaN is just a correction to avoid division by zero).
To print the vectors i would add a constructor in interfaceProperties.C (also modify interfaceProperties.H accordingly) with the declaration of nHatfv (something similar to what you find for the other variables).
Then you can call it in the main code using
interface.nHatfv()
Hope this help
Andrea
Old   June 24, 2015, 13:13
HM
Andrea,
Thanks for the reply, I went the procedure you had mentioned and I get this error:
from my_interFoam.C:43:
/home/magma/OpenFOAM/OpenFOAM-2.3.1/src/transportModels/interfaceProperties/lnInclude/interfaceProperties.H:129:9: error: ‘const surfaceVectorField& Foam::interfaceProperties::nHatfv() const’ conflicts with a previous declaration
/home/magma/OpenFOAM/OpenFOAM-2.3.1/src/transportModels/interfaceProperties/lnInclude/interfaceProperties.H:73:21: note: previous declaration ‘Foam::surfaceVectorField Foam::interfaceProperties::nHatfv’
/home/magma/OpenFOAM/OpenFOAM-2.3.1/src/transportModels/interfaceProperties/lnInclude/interfaceProperties.H: In member function ‘const surfaceVectorField& Foam::interfaceProperties::nHatfv() const’:
/home/magma/OpenFOAM/OpenFOAM-2.3.1/src/transportModels/interfaceProperties/lnInclude/interfaceProperties.H:128:20: error: invalid initialization of reference of type ‘const surfaceVectorField& {aka const Foam::GeometricField<Foam::Vector<double>, Foam::fvsPatchField, Foam::surfaceMesh>&}’ from expression of type ‘<unresolved overloaded function type>’
my_interFoam.C: In function ‘int main(int, char**)’:
my_interFoam.C:106:3: error: ‘interface’ was not declared in this scope
Old   June 24, 2015, 13:14
HM
But I think the main problem is the following error:
Old   June 24, 2015, 14:13
Andrea Ferrari
Did you compile the library (interfaceProperties) after implementing the changes?
anyway you have two errors...try to post here the changes you did
Best,
Andrea
hojjat.m likes this.
Old   June 24, 2015, 14:27
HM
Andrea,
You were right, I hadn't compiled it, now that I have compiled it, when I add
interface.nHatfv();
I get the following error again:
This is the only error I get, is it because of the version that I am using, I am using openFoam 2.3.x
Old   June 24, 2015, 14:40
Andrea Ferrari
try with
mixture.nHatfv();
Old   June 24, 2015, 14:50
HM
Actually, I had tried this, but I get this error:
In file included from /home/magma/OpenFOAM/OpenFOAM-2.3.1/src/transportModels/immiscibleIncompressibleTwoPhaseMixture/lnInclude/immiscibleIncompressibleTwoPhaseMixture.H:39:0,
/home/magma/OpenFOAM/OpenFOAM-2.3.1/src/transportModels/interfaceProperties/lnInclude/interfaceProperties.H: In function ‘int main(int, char**)’:
/home/magma/OpenFOAM/OpenFOAM-2.3.1/src/transportModels/interfaceProperties/lnInclude/interfaceProperties.H:73:28: error: ‘Foam::surfaceVectorField Foam::interfaceProperties::nHatfv’ is private
my_interFoam.C:109:10: error: within this context
my_interFoam.C:109:17: error: no match for call to ‘(Foam::surfaceVectorField {aka Foam::GeometricField<Foam::Vector<double>, Foam::fvsPatchField, Foam::surfaceMesh>}) ()’
I mean it works for mixture.nHatf(), but not for mixture.nHatfv()
But nHatf=nHatfv.sf is the surfaceScalar field, not the one that we want
Old   June 25, 2015, 06:18
Andrea Ferrari
I tried with OF 2.1 and it works. This is what i have done:
1) in interfaceProperties.C
- removed the declaration of nHatfv
- add
nHatfv_ = gradAlphaf/(mag(gradAlphaf) + deltaN_);
correctContactAngle(nHatfv_.boundaryField(), gradAlphaf.boundaryField()); //just add "_"
// Face unit interface normal flux
nHatf_ = nHatfv_ & Sf; //Just add "_"
- In "Constructors" add (after the declaration of nHatf_)
nHatfv_
IOobject
"nHatfv",
U_.time().timeName(),
U_.mesh()
U_.mesh(),
dimensionedVector("nHatfv", dimless, vector::zero)
2) in interfaceProperties.H
-add (after the declaration of nHatf_)
surfaceVectorField nHatfv_;
-in "Member Function" add (after the declaration of nHatf_)
const surfaceVectorField& nHatfv() const
return nHatfv_;
3) Re-compile interfaceProperties with "wmake libso"
4) in interFoam.C add
surfaceVectorField n = interface.nHatfv(); //(here you probably have to change "interface" with "mixture")
n.write();
5) Re-compile interFoam with "wmake"
I tried right now and it works, i am not 100% sure that the correction for the contact angle at wall is taken into account when you write nHatfv(), you may want to check this.
Best,
Andrea
Old   June 25, 2015, 11:00
HM
Andrea,
Thank you very much for the response, I tried the procedure that you had mentioned, and it compiles perfectly, but when I enter interFoam to start the simulations, I get the following error:
--> FOAM FATAL ERROR:
Different dimensions for =
dimensions : [0 2 0 0 0 0 0] = [0 0 0 0 0 0 0]
From function dimensionSet:perator=(const dimensionSet&) const
in file dimensionSet/dimensionSet.C at line 171.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/magma/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::error::abort() in "/home/magma/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 Foam::dimensionSet:perator=(Foam::dimensionSet const&) const in "/home/magma/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#3 Foam::GeometricField<Foam::Vector<double>, Foam::fvsPatchField, Foam::surfaceMesh>:perator=(Foam::tmp<Foam::Geom etricField<Foam::Vector<double>, Foam::fvsPatchField, Foam::surfaceMesh> > const&) in "/home/magma/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/libinterfaceProperties.so"
#4 Foam::interfaceProperties::calculateK() in "/home/magma/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/libinterfaceProperties.so"
#5 Foam::interfaceProperties::interfaceProperties(Foa m::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::IOdictionary const&) in "/home/magma/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/libinterfaceProperties.so"
#6 Foam::immiscibleIncompressibleTwoPhaseMixture::imm iscibleIncompressibleTwoPhaseMixture(Foam::Geometr icField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/home/magma/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/libimmiscibleIncompressibleTwoPhaseMixture.so"
in "/home/magma/OpenFOAM/magma-2.3.1/platforms/linux64GccDPOpt/bin/my_interFoam"
#8 __libc_start_main in "/lib64/libc.so.6"
at /home/abuild/rpmbuild/BUILD/glibc-2.15/csu/../sysdeps/x86_64/elf/start.S:116
Aborted
Thanks,
Hojjat
Old   June 25, 2015, 11:28
Andrea Ferrari
I don't have this error. Remember that OF always checks about dimensions.
nHatfv is dimensionless and you are setting nHatfv equal to something which has dimension of m^2. This generates the error.
debug your code and try to understand from where the error comes.
Best,
Andrea
Old   June 27, 2015, 15:51
HM
Done,
Thank you very much, ur suggestions really helped.
Rising bubble with interFoam tayo OpenFOAM Running, Solving & CFD 16 March 12, 2020 13:11
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
[snappyHexMesh] Layers don't fully surround surface EVBUCF OpenFOAM Meshing & Mesh Conversion 14 August 20, 2012 05:31
Cross section and surface area factor Fabiana CFX 0 January 10, 2006 00:51
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
